Radiant Barrier Test - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 08-05-2014, 12:23 AM   #1
Question
I already purchased some radiant barrier products and it's really help in reducing the heat gain into my house and now I am planning to install more. So I surf the internet to find more information about it and found some technical data sheet. I don't really understand why radiant barrier must undergo for wet delamination test, folding endurance test and shrinkage test? i mean, does all these tests are really crucial as if not doing it will effect the radiant barrier's performance? Because as I know radiant barrier must be install in dry condition and left in dry condition. Does the folding endurance & shrinkage have any effect to the performance? Because after we have done with the installation, there is no more folding or unfolding the radiant barrier. I need help with these. someone please enlighten me. thank you in advance.
Ooi Eng Hong is offline   Reply With Quote
Old 08-05-2014, 05:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
ummm....no.
Most materials will have to go through several tests that they should not, ideally, be subjected to.
If it stays dry, you shouldn't have any issues.
Tags
folding endurance test , radiant barrier , reflective insulation , shrinkage test , wet delamination test
Can you use a radiant barrier foil for underlayment for engineerd hardwood flooring marleybird Flooring 0 05-08-2011 12:00 PM
Radiant Barrier + Insulation with Metal Roof customfab Building & Construction 8 02-16-2010 09:47 PM
Radiant Barrier Insulation SPS-1 Building & Construction 0 10-26-2009 07:16 PM
steam v. hot water, radiant sub-system Lor HVAC 1 06-11-2009 03:58 PM
