Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Green Home Improvement
Old 01-25-2010, 12:25 PM   #1
question about spray foam
I was wondering, what's the difference between open cell and closed cell spray foam? Why is spray foam considered a "green" building product? Also, is there a specific spray foam be used to plug up cracks in foundations that are infiltrated by water? THanks
Tonglebeak is offline   Reply With Quote
Old 01-25-2010, 12:41 PM   #2
Military Mom of 4
Snav's Avatar
Great stuff makes some different types of foams that can be used to fill cracks and so forth - the type made for windows and doors will keep out water so long as it's not a lot of water or water that exudes constant pressure on the foam.
That's all I know
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 01-25-2010, 02:00 PM   #3
Can it hold up back something like this?
http://www.youtube.com/watch?v=aTUTENi5DQo
Old 01-25-2010, 02:08 PM   #4
Military Mom of 4
Snav's Avatar
Ahhahaha - that sucks.
And no.
That type of damage requires serious repair - not just some crack-filler.
If you did inject foam-sealant into such an area it wouldn't fill every single nook and cranny - the water will make it's way in somehow by following the path of least resistance.
Even if it did work it simply would keep the water from coming into your basement, it would not keep the water from filling up your wall-area and sub-house (underneath the basement). . . .and you will still have problems, they will just be new problems.
Old 01-25-2010, 02:14 PM   #5
Times like these makes me want to just puncture holes into the basement wall and the throw gravel on the floor to make a french drain floor @_@
Old 01-25-2010, 02:16 PM   #6
Military Mom of 4
Snav's Avatar
Heh . . . I'm glad I don't have a basement - they tend to flood alot!
Fill it in - make it a slab :D Kidding!
Now, I would be nice about it and do it final and do it right - really repair it the right way (even if it means hiring in a pro). In part because i'm sure the previous owners "patched" it up - and just passed it on to you and crossed their fingers hoping they'd be long gone before it failed.
So don't be "that" guy to the next guys.
Old 01-25-2010, 02:30 PM   #7
I know how you mean. With that said this is the first time it's been _that_ bad...and here's why it's been this bad (I think):
http://www.youtube.com/watch?v=L_6RBsmWozk
Making the water table a bit high I guess >_> That "creek" is usually a trickle, not this.
Old 01-26-2010, 09:22 AM   #8
sdsester's Avatar
You may want to consider a perimeter system around the house to see if you can keep the water away from the basement. Check grading and drainage. Check your downspouts and gutters.
Once you address these there are injectible concrete repair compounds that would be better choices than foam. I use this company's products quite a lot but there are others out there as well.
http://www.abatron.com/cms/buildinga...nproducts.html
If the damage is severe or I am not sure about it, I don't mess around. I call a mason or concrete walll repair pro.
sdsester is offline   Reply With Quote
Old 02-04-2010, 01:14 PM   #9
I just bought some Great Stuff...and I am absolutely sold..
Old 02-04-2010, 06:05 PM   #10
Why didn't anyone warn me that this would happen?
Old 02-04-2010, 06:11 PM   #11
nap
You talking to me?
nap's Avatar
you must have gotten a contaminated can of foam. Mine have never had anything like that in them.
Old 02-04-2010, 06:38 PM   #12
sdsester's Avatar
I have encountered this in basements. Now I know where the slithery critters came from! The spray foam cans. Now that I look, the label did say it was for sealing voids and controlling rodents.
Tonglebeak, by the way. Could you click on your username when signed in and update your profile to include at least a basic location? It may help us in responding to your posts.
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
Question about spray painting DexterConnector General Discussion 2 05-24-2009 08:40 AM
Shingling, Cathedral Ceiling, Spray Foam & Venting blues Roofing 7 05-14-2009 02:35 AM
Spray foam degradation Timberwright General Discussion 6 01-28-2009 10:41 PM
DIY Contractor Spray Urethane Foam TomHay Building & Construction 5 07-10-2008 10:26 PM
