Question About Placement Of One Of Those Big Flat Tv's - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 11-24-2014, 12:47 PM   #1
i carved this sword
feralfreak's Avatar
Rewards Points: 91
question about placement of one of those big flat tv's
I was wondering something, im not sure if this is the right forum for it, but if its not I guess a moderator will move it, I was wondering, if a person would have a fireplace, and that fireplace would have one of those stove inserts, and it was one that stuck out far enough to maybe do a little light cooking on(heating soup or grilled cheese or something just for the sake of the question, I don't know if one like that actually exists), would it be safe for a big tv to be put on the wall above it? or would rising heat be damaging to it? would an extra wide mantle be needed or would that make any difference? I don't have a house with this feature but I thought of seeing if something like that can be put into a plan I was kinda working on.
feralfreak is offline   Reply With Quote
Old 11-24-2014, 02:39 PM   #2
Rewards Points: 153
Yeah, wrong forum I'd say.
But anyway, I don't think having any sort of heat source below a flat screen would be good for it. I doubt a wide mantle would help, heat would probably just flow up, around the mantle and below the TV.
52Caddy is offline   Reply With Quote
Old 12-01-2014, 01:37 PM   #3
AMHope's Avatar
Rewards Points: 16
Definitely bad placement - you need to have cool air for the vents around TV - not extra heated. Also - the heat waves will distort the view of the tv whenever the stove was on. If there were liquids on the stove as described then the steam would end up inside the tv casing.
AMHope is offline   Reply With Quote
Old 12-02-2014, 04:56 AM   #4
i carved this sword
feralfreak's Avatar
Rewards Points: 91
ive seen where some have had a tv put over a fireplace above the mantle, why would they do that? wouldn't the heat from that cause some issues? or is it different with a fireplace instead of a stove?
Old 12-16-2014, 04:23 PM   #5
Rewards Points: 12
yes it will make your TV is broken, because the heat generated fire place. Maybe you can change the layout of the sofa and also the eye in order to be able to enjoy television without fear of broken quickly caused the heat of your fire place.
lencarifin is offline   Reply With Quote
Old 02-03-2015, 05:19 AM   #6
Yes and No.
This might sound ironic, but yes you can! Heat form the steam coming out of the food you're cooking can only reach as high as 2 feat. Anything above that is safe. The only problem, however, are the residue that goes with the steam. They get will fog your television for sure.
Vince86 is offline   Reply With Quote
Old 02-04-2015, 09:34 AM   #7
Rewards Points: 202
Well it is certainly possible but I think it's not the best placement. Heat waves from the fireplace will distort the view if it is on. Also, if the fireplace is turned on the TV would also overheat faster that it should.
-Paul
PD_Lape is offline   Reply With Quote
Old 02-04-2015, 09:41 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 3,700
The worse enemy of electronics (beside too many excited electrons) is heat.
Now, if you have a mantle that somewhat shields the heat from rising directly into the TV, you might be ok.
But, heat is the worst enemy.
Old 02-04-2015, 10:41 AM   #9
Personally I would never place an expensive piece of electronics over a heat and smoke generating fireplace. Perhaps an enclosed inset gas log fireplace . Personally I hate the look and every time I go to a friends house and watch the tube that high in the wall I have to go for a massage to get the kinks out of my neck.
jimn01 is online now   Reply With Quote
Air conditioner condenser placement question sbkim HVAC 5 07-04-2012 12:43 PM
question about brick patio base vipergtsxz Landscaping & Lawn Care 5 06-30-2012 02:17 PM
Cannot match sheen on flat paint? infiniti23 Painting 4 12-10-2010 04:35 PM
Sub-Panel Placement Question KC10KEVIN Electrical 10 05-09-2008 09:40 AM
flat roof question sflamedic Roofing/Siding 4 04-28-2008 11:41 PM
