Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Green Home Improvement
Old 10-04-2012, 07:14 PM   #1
Lightbulb
PV Solar electricity tied directly to a DC Water Heater
There are DC heater elements available for use in electric water heaters. Therefore, can PV Solar panel output (DC) be directly wired to a DC Water Heater of the matching voltage (assuming a thermal controller is installed to prevent over heating). Any ideas or brain storming?
Thanks,
Joe
JStofik is offline   Reply With Quote
Old 10-04-2012, 09:41 PM   #2
Missouri Bound's Avatar
Why not? What heats the water when it's cloudy?
Do you want it your way or the right way?
Old 10-05-2012, 10:15 AM   #3
On cloudy days, the existing gas hot water heater will supply hot water. It will be plumbed so the DC electric is a feed tank to the existing gas water heater.
Old 10-05-2012, 10:24 AM   #4
Got it!
Old 11-09-2012, 10:50 PM   #5
You can do this, but energy-wise it is a waste of panel area. You would get more heat into the water using indirect solar thermal instead of PV.
You generally only get about 10% of your incident solar into the form of electricity in PV. Solar thermal is far more efficient if your goal is to make hot water.
Thunder Chicken is offline   Reply With Quote
Tags
hot water from a pv
Best practices for Water Heater install? simanco Plumbing 4 08-23-2012 12:36 AM
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
