Propane Mower Conversion - Green Home Improvement - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 09-01-2010, 09:08 AM   #16
Originally Posted by homerb View Post
An on demand regulator is the one part I didn't use on this project. Being that I only paid $40 for the mower itself, I wanted to keep it as low budget as possible.
I can extend the runtime on the mower by simply throttling it down a bit. The rpm and mixture auto adjust based on how much propane goes into the mower.
I am interested in using an on demand regulator for my next project, which will need it. I have a generac 7500 w / 13,500 w peak generator that can power my whole house. I haven't converted it to propane yet because I need that on demand regulator. With the mower, I can constantly adjust the propane flow as needed, but the generator needs to be much more reliable, and it needs to auto adjust the flow based on how much stuff I have running in the house.
I haven't even needed to use the generator once since I bought it from the pawn shop for $275, so I don't even know how much gas it uses per hour. But propane is a much better choice because it stores better, doesn't foul plugs, gum up the carb, and extends oil change intervals. Im guessing it'll run for about 4 hours on a typical 20lb tank at half load. Im hoping it'll run longer, if it is to be cost effective though. I could get one of those big 100lb tanks and have it run all day without changing a tank.
What kind of on demand regulator are you planning to use? I've been looking on eBay lately and there are a few different kinds on there.
Homer
Garrettson SD is the ticket, or perhaps the KN with auto-primer. For your generator, you will want one that has an electric shut-off solenoid for positive cut-off when the engine stops. You don't want the engine to shut down and fuel to keep leaking through.
http://www.propane-generators.com/garretson.htm
littlehorn is offline   Reply With Quote
Old 09-01-2010, 11:01 AM   #17
What are the other details of your project? In addition to the regulator, what mower are you going to be using? What kind of propane tank?
Are there any other modifications you are making to the mower to make it more powerful or efficient running on propane? Bumping the compression or timing are probably the easiest and most effective modifications you can do.
Post some pics if you can!
homerb is offline   Reply With Quote
Old 09-16-2010, 12:38 PM   #18
How about the noise factor? I imagine it would be quieter but Im not sure.....
happycamperbrat is offline   Reply With Quote
Old 09-16-2010, 01:01 PM   #19
It sounds about the same at normal operating RPM. However, since increased the compression ratio and advanced the ignition timing, it sounds a little different. But none of that has to do with the propane directly.
I can make it louder or quieter though...just by adjusting the RPM's with the propane valve.
Old 02-13-2015, 12:43 PM   #20
Grognard
andrew4096's Avatar
Rewards Points: 12
... I was thinking of mounting a second tank on the other side and tapping it in using a T-fitting. When using one bottle, it gets cold after about 10 minutes of mowing which reduces the bottle pressure. When I'm nearing 1/4 full on a tank when it's cold, often it won't supply enough pressure to keep the engine running. I'll have to switch to another tank (often another partially full tank from the last time I mowed the lawn) or soak it in a tub of hot water. Two tanks would eliminate this problem because I could switch over, or just run both half as much.
Some do-it-yourselfers have solved, perhaps inadvertently, the propane cylinder chilling problem by mounting larger cylinders on their mowers. For example, see YouTube video 9F9FhK0SdRE, posted December 2013, where the fellow has mounted what appears to be a small 5-pound barbecue cylinder on the mower deck. (He may be in Australia, and the LPG equipment available there varies from what we can get in North America.) It adds weight and makes the mower a bit ungainly, but the larger mass of liquid propane, plus the larger surface area of the cylinder, help reduce the rate at which it cools as gas is being drawn off. If one would rather deal with the small, 1-pound disposable cylinders, connecting two of them with a T-fitting as you suggest and simultaneously supplying gas from both would have a similar effect, as the rate of flow from each cylinder would be cut in half and the surface area would be doubled. It should make little difference whether you use the narrow 1-pound disposable cylinders for propane torches or the squat 1-pound cylinders used for camp stoves and lanterns, as their surface areas are essentially the same, within a few percent.
andrew4096 is offline   Reply With Quote
Old 01-26-2016, 12:34 AM   #21
Something I am for sure going to try once the weather warms up.
Tip:
If you mount the bottle upside-down, when it gets cold it will still flow.
ICan'tPickAName is offline   Reply With Quote
The Following User Says Thank You to ICan'tPickAName For This Useful Post:
Jim F (03-04-2016)
Old 03-16-2016, 05:42 PM   #22
bradleyshome's Avatar
Rewards Points: 114
Re: Propane Mower Conversion
The coolest part is that the blue propane bottle looks like a NOS nitrous tank. VROOOOOMMM!!!
Haha get some NOS stickers to add an extra 25hp
bradleyshome is offline   Reply With Quote
natural gas to propane conversion Brian U Appliances 1 09-28-2009 12:36 PM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 04:57 PM
williams direct-vent propane conversion leach HVAC 2 12-18-2008 02:51 PM
Propane to Natural conversion higgsfamily5 Appliances 5 11-06-2008 10:51 PM
oil burner to propane conversion mikevacarr HVAC 4 06-20-2008 11:38 PM
