Passive Solar Trombe Wall - Green Home Improvement - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 01-15-2012, 08:59 AM   #16
UsingtheSUN
ChiefVOL's Avatar
Originally Posted by oh'mike View Post
This is a pretty amazing site---Glad you came---Mike---
It is so good you may live to regret I ever discovered it. I have no knowledge, only questions.. fortunately I have found a great source for answers. THANKS
ChiefVOL is offline   Reply With Quote
Old 01-15-2012, 09:20 AM   #17
DIY staff
Rewards Points: 7,174
See if your library has old copy's of "The Mother Earth News" from the late 1960s and early 1970s.
Lots of cheap energy--off the grid---ideas---
Old 01-22-2012, 10:26 AM   #18
Rewards Points: 410
Here's a SIP/post and beam hybred that I had a chance to tour under construction and after completion.
The owner and GC had my head swimming with all the efficiency technics they were using.
http://solarhomesus.com/energy_deman...ts_-_pura_vida
High Gear is offline   Reply With Quote
The Following User Says Thank You to High Gear For This Useful Post:
ChiefVOL (01-22-2012)
Old 01-22-2012, 11:52 AM   #19
concretemasonry's Avatar
Rewards Points: 2,608
What does a SIP construction have to do with a Trombe Wall? Usually, they are not compatible since passive solar heat depends on mass to be efficient and store heat and maintain uniform temperatures.
Dick
concretemasonry is offline   Reply With Quote
Old 01-22-2012, 12:58 PM   #20
UsingtheSUN
ChiefVOL's Avatar
I am a little lost - what is SIP. This house I am designing will be 750 sq. ft. The trombe wall will be 24 feet long, 8 feet high, made of grout filled cinder block
Old 01-22-2012, 02:19 PM   #21
Rewards Points: 410
Ooops see what happens on a Sunday morning with not enough
coffee in me!
I've had my fill of coffee now though.
Same GC different house using a Trombe wall.....
http://www.kickapoomudcreek.org/syst...MasterPlan.pdf ( pages 14,15)
http://www.kickapoomudcreek.org/dwelling ( click design ( show trombe wall interior also there's 105 pics on construction )
Don't know if there is any info here to help .....
Previous post was just showing there is more than 1 way to skin a
cat ..they were capturing heat off the roof among other things and
running it down through a interior thermal wall.
EMD360 (06-15-2012)
Old 01-22-2012, 04:41 PM   #22
UsingtheSUN
ChiefVOL's Avatar
thanks for amending, I was lost.
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
