#1 |
UsingtheSUN
Passive solar Trombe Wall
How much grout will I need to fill a cinder block wall 130' x 8' using 8x8x16 blocks? Should I use PVC or EMT for electrical conduit? How to pre-plumb?
#2 |
Super Moderator
We need more details----where are you? What does local code allow for electrical conduit?
Is this an outside wall? Will freezing be a problem for plumbing? What plumbing?
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
For the grout, figure on using about 50% of the volume of the wall. That is based on a typical 8x8x16 block and special units may require a somewhat different amount. Since it is a Trombe Wall, it is probably not structural and the goal is just to get as much mass into the wall.
Dick |
#4 | |
UsingtheSUN
Passive solar Trombe WallQuote:
May I hire you as a consultant?? Last edited by ChiefVOL; 01-12-2012 at 12:22 PM. |
#5 |
Best bet is to Google tromble walls. Plenty of reputable sites have info on them.
#6 | |
UsingtheSUN
1. Should I vent the heated area between glass and wall for summertime, i.e. chimney effect 2. How much distance should I have between inner glass and mass wall 3. Can I build the double paned glass myself with two pieces of glass and does it need to be a vacuum between the two pieces of glass 4. Should I use grout or sand to fill the cinder blocks - cost v efficiency I plan on doing ALL the work myself, or as much as possible. I have a limited budget with time on my hands... Any and all input would be greatly appreciated. Work is to be in Sequatchie County, TN |
#7 | |
#8 | |
UsingtheSUN
I want to build and install a solar water collector on the roof - 50 gallon capacity. How much reinforcement will I need for the rafters and ceiling joists? I plan on as little slope as possible for the roof? As far as I know, I will not be subject to building codes in Dunlap, TN for this construction. While erecting the cinder block walls - and before filling with grout/sand, I want to install electrical conduit and needed plumbing. I plan on doing ALL of this construction myself. I am rather poor and not very bright. Any and all help would be greatly appreciated. |
#9 |
Moderator
Have you given much thought to other passive heating storage systems, specifically water? Or are you set on T.W.'s, though they don't have much for overcast days storage.....
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#10 |
Chief -
You can use sand in the cores to increase the thermal mass of the wall. The resulting wall weight/density will be slightly less, but still far superior to a lightweight wall that offers the benefit of the sun. They also do offer thermal benefits on cloudy days and even at night (thermal inertia). You may want to find a way to "dump" the excess heat when it is not needed. I have never seen a Trombe Wall that created or was involved in a moisture problem. The ventilation and humidity inside the house will control the humidity since it is steady state situation as opposed to what happens in a lightweight home. concrete is a great modulator of both heat and humidity. If the home is opened up in humid season, the concrete can slowly absorb some of the humidity and if the home is too dry in the winter, it can give off limited moisture for a relatively short period of time. - That is why HVAC engineers can downsize the heating and air conditioning systems and improve the livability. Dick |
#11 | |
UsingtheSUN
Thanks for your input. |
#12 | |
UsingtheSUN
I am planning this home for my retirement - in a few years. I do not have much money and looks like I will be living on around $800.00/month after retirement in 8 years. With help from folks like yourself, I am absorbing as much info as possible, then hope to build this little home myself. I assume you are a mason. I plan on pouring a 40 x 25' 4" slab floor then lay the cinder block wall (dry stacked ) on the slab. The south facing wall will serve as the trombe wall. Are you familiar with dry stacking block. I have read a rookie like myself can do it. How many rows of block can I lay before pouring cement into the cores. I will only pour cement into the trombe wall. I hope to use some synthetic pellets or foam in the non-trombe block walls as they will only serve as insulating walls. Any and all input you can provide will be greatly appreciated! |
#13 |
Moderator
In a few years, I plan to buy/remodel/addition a small house-800sq.ft. enlarging it to 1000sq.ft. One level, two bedroom, 1&1/2 bath retirement home. I researched TW's but the 7-10 no-sun days (or longer) around here discouraged me. I want passive solar, with back-up electric heaters, solar water pre-heating, and vestibules at back/front door to keep the heat inside the cellulosed double-walls. Here are some of my study sites; http://www.greenbuildingadvisor.com/...xport/html/494
http://www.energysavers.gov/your_hom.../mytopic=12480 http://soe.rutgers.edu/files/Arch.pdf http://www.energysavers.gov/your_hom.../mytopic=12850 http://www.builditsolar.com/Projects...er_heating.htm http://www.builditsolar.com/Projects...ce_Heating.htm Some of the ones I am going with: http://www.n3fjp.com/solar/solarhotair.htm http://www.ibiblio.org/london/renewa.../msg00026.html http://www.ibiblio.org/london/renewa.../msg00025.html http://www.ibiblio.org/london/renewa.../msg00011.html A drain-back solar or a pre-heater finned-line to a tank incorporated in the solar closets, and an ERV rather than a HRV which dries the air out. You may also want to check out 2’ of sand under the slab with passive air heating ducts run through them for longer term than a TW. With a wood stove, the TW may all you need. Gary
#14 | |
UsingtheSUN
| The Following User Says Thank You to ChiefVOL For This Useful Post: | Gary in WA (01-15-2012) |
#15 |
Super Moderator
This is a pretty amazing site---Glad you came---Mike---
| Display Modes | |
| Retaining wall problem | FMS | Landscaping & Lawn Care | 6 | 07-04-2011 07:42 PM |
| Removing a wall with no ceiling joist above it | i77ac_10 | Building & Construction | 2 | 01-05-2011 01:30 PM |
| Advice on retaining wall replacement (pics inside) | eastie | Building & Construction | 0 | 04-05-2010 11:32 AM |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
| Load Bearing Wall? | Traybae | Building & Construction | 1 | 11-05-2006 02:01 PM |
