Need Natual Lubricating Oil - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 07-31-2009, 09:52 PM   #1
I need a natural lubricating oil for tools, machines...
applebuilder is offline   Reply With Quote
Old 08-01-2009, 08:27 AM   #2
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Use vegetable oil, the type is your choice. I have used it for years, doors, wrenches, locks ect... dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 08-03-2009, 11:49 PM   #3
Do you know of any that won't go rancid quickly? what is dorf dude?
Old 08-04-2009, 02:30 AM   #4
Dorf dude...
dorf dude
My house is in a dorf and I am a dude, dorf dude.
Old 08-04-2009, 10:41 AM   #5
(the original)
Rewards Points: 756
No, there isn't one that won't turn rancid eventually. And don't use unmodified veg oil on any kind of machine. It congeals when it gets cold, burns when it get hot, and won't hold viscosity at any temp. I've heard of people using used deep fryer oil in chain saws as bar oil, but that stuff has stabilizers added. I'll stick with bar oil for now, myself.
Castrol has some bio based products in Europe, but I think we're a still a couple years away from seeing much readily available in the US. You might do a search for "bio based lubricants".
The only things I've seen much of so far are "green" lubes in bicycle shops. Those would probably serve a lot of your needs. IIRC, I also saw a Lubrimatic bio based grease somewhere recently.
ratherbefishin' is offline   Reply With Quote
Old 08-04-2009, 02:01 PM   #6
Dorf dude...
Try here http://www.halocarbon.com/oils/
Old 08-06-2009, 03:44 AM   #7
thanks for the links and tips, time to do some research...
Old 08-07-2009, 11:22 PM   #8
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I have used this product, SoyClean Soy-Based Penetrant & Lubricant . Worked great, not sure how it will work over time though...
Last edited by Mr Chips; 08-10-2009 at 02:04 PM. Reason: forgot to insert the hyper link
Mr Chips is offline   Reply With Quote
Old 08-10-2009, 01:54 PM   #9
Rewards Points: 1,910
Just use a light weight motor oil. It doesn't get any more natural. Comes right out of the ground with less processing than vegetable oils. No pesticides, no genetically modified organisms.
lubricating ABS for dry fit DB larry Plumbing 3 09-22-2008 05:21 PM
