Need Foam - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 05-23-2009, 01:34 AM   #1
Need Foam
I figured this might be the best place to ask, I'm looking for foam that can either be cut easily or mold poured. It also needs to have some wieght to it, but either breaks or collapsed on light impact. Any suggestions would be greatly appreciated.
KrispyKreem is offline   Reply With Quote
Old 05-26-2009, 08:58 AM   #2
Rewards Points: 596
Hi Krispy Kreem, welcome to the forum.
The Dap brand foam for sealing gaps can be molded and, in my experience, it crumbles easily after it sets for a while. But it does not have much weight to it.
Are you making fake Krispy Kreem doughnuts with it? LOL
gma2rjc is offline   Reply With Quote
Old 05-26-2009, 09:08 AM   #3
the Musigician
DangerMouse's Avatar
need more input. what are you trying to make?
DM
Old 05-26-2009, 02:19 PM   #4
Rewards Points: 348
I assume you are making some kind of device to protect an object during impact??? Try using one of the spray foams meant for doors and windows. Just be sure to supply a little moisture if you are filling a large form and try to do it is layers if it is more a few inches thick.
Rege
RegeSullivan is offline   Reply With Quote
Old 05-28-2009, 10:40 AM   #5
It's to create a impact barrier on a new little trinket i'm working on (Part time inventor) the weight is somewhat impartant but not nearly as important as it is that it breaks on impact. Thanks for the responses so far, I'll take a look into them... hehe.. counterfeit Krispy Kreems.
Old 05-28-2009, 11:28 AM   #6
the Musigician
i know of a couple things, although because i do not know what this is for, i don't think it's a good idea to say.
this could be dangerous.
DM
Old 06-02-2009, 10:36 AM   #7
I'm in my late fifties with no dependents, if it has a chance to blow me up, set me on fire, or otherwise maim me don't worry.
Old 06-02-2009, 11:04 AM   #8
the Musigician
it wasn't you i was worried about......
DM
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 03:07 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Synthetic Stucco over XPS foam techinstructor Building & Construction 6 07-12-2009 09:23 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
