Nansulate HomeProtect - Any Thoughts Or Experience With It - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 08-28-2009, 01:16 PM   #1
Rewards Points: 109
Nansulate HomeProtect - any thoughts or experience with it
First of all, I have no experience or invested interest in it. I heard about it from my coworker who used it in his house and noticed considerable improvement.
I am considering using this on our house and would like to see what you guys and gals think
http://www.nansulate.com/Nansulate_and_LEED.htm
BimmerRacer is offline   Reply With Quote
Old 08-28-2009, 06:27 PM   #2
Rewards Points: 178
Did your co-worker do the work himself?
gma2rjc is offline   Reply With Quote
Old 08-28-2009, 08:09 PM   #3
Rewards Points: 150
I have not used Nansulate, but I have used an additive by Hy-Tech:
http://hytechsales.com/insulating_paint_additives.html
At first, I was skeptical. I purchased enough for 1 gallon to try. I painted the ceiling of the hallway of my ranch house in Illinois. During mid November, later that year, I was in the attic working on some electrical stuff, and had moved the insulation above one of the bedrooms. The backside of the sheetrock was very warm to the touch. I then went over the hallway, and checked the same, and it was cool to the touch! WoW! It had worked. I since have painted the outside walls to the bedrooms and bath, and noticed a huge difference. I also coated the subfloor of my bathroom with their Barrier Coat#85 prior to installing electric warm tile floor heat system, and have noticed similar results. Instead of installing a water heater blanket, I mixed a small batch of enamel and painted the outside of my 1976 water heater. Instead of being very warm to the touch on the outside, it is now cool, and I turned the thermostat down under the normal setting. This past summer I painted my entire living/dining room, and cannot wait to see the results this winter.
Now, results may vary, but these are my results. I bought the additive, and added directly to my standard latex paint. As they say, it does add a bit of texture, but my walls were textured already, so no biggie for me. I also noticed that if you are mixing an entire gallon, buy a 2 gallon container with lid. The entire contents will not fit in a single gallon can. Also, I added about 4-8 oz. of flowtrol, which helps with "spreadability" of the paint. The additive tends to thicken it up, and the flowtrol helps.
It looks as if their prices have gone up quite a bit, but in bulk they offer free shipping. Still cheaper than insulation.
Word of caution... there are imitators out there, and they are not as effective. Been there done that.
TJ
BTW... I am in no way affiliated with them. The link is not a referral link. I just like spreading the word about a good thing, and like saving energy (and money), and think others will enjoy the same.
If you questions, please ask.
TJ_in_IL is offline   Reply With Quote
Old 08-28-2009, 08:36 PM   #4
Rewards Points: 178
TJ, if this paint is used to paint the surface of a stud where drywall is attached, do you think it would prevent cold air from outdoors transferring through the studs and drywall into a room?
Old 08-28-2009, 08:48 PM   #5
Rewards Points: 109
He did, its just like applying regular paint, from what I understand
Old 08-28-2009, 10:51 PM   #6
Rewards Points: 150
Quite possibly. Why not just paint the whole wall? Can be mixed with the primer, and then top coated with whatever paint you want. The nice thing is, no matter how may times you top coat with regular paint, it still works.
vapor barrier repair - conflicting ideas - thoughts appreciated pendlebg General DIY Discussions 1 07-20-2009 06:45 AM
New Electric Convection Heating Panels--Any Experience? akimbo HVAC 19 05-27-2009 12:42 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 05:12 AM
Non-Gas powered mowers. Experience? Thoughts? IckesTheSane Landscaping & Lawn Care 3 12-03-2008 02:04 PM
Thoughts on Cheap Flooring Idea Needed! MissyM Flooring 4 09-01-2007 08:51 PM
