Insulated Plaster Board - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 12-12-2008, 11:50 AM   #1
Insulated plaster board
I am in the process of plastering the interior of my exterior walls with thermalcheck.k plasterboard but need to make a decision about the thickness of the board. The walls are the thickness of two bricks without cavity. Apparently there is a law of diminishing returns in respect of the thickness of the board. I am considering 40mm or possibly 50mm board. Could anybody advise since I am in the dark?
John Ryan is offline   Reply With Quote
Old 12-16-2008, 10:11 AM   #2
home improvement guru
aaron.klimchuk's Avatar
I wish I could help you out here, but I'm sure someone will chime in soon.
aaron.klimchuk is offline   Reply With Quote
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
replacement of plaster board abc Remodeling 2 03-28-2008 03:56 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
