Insulate Cellar? - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 04-24-2009, 10:04 AM   #1
Insulate Cellar?
This is a pic of the ceiling of my cellar. There is no access from inside the house and I was wondering if the lack of insulation is the cause of the first floor being cold all the time.
This is how I bought the house and the inspector said i did not need to insulate. The cinder blocks you see the beams of the house sitting on is exposed to the elements so would it be safe to say I am loosing heat through the cellar?
If so how do I insulate the cinder block wall?
newbieowner is offline   Reply With Quote
Old 04-24-2009, 08:27 PM   #2
I would insulate the outer sill plate all the way around
That & replacing single pane windows w/new double pane LOW e made a huge difference
Old 04-24-2009, 08:45 PM   #3
Rewards Points: 336
Is this a crawl space?
gma2rjc is online now   Reply With Quote
Old 04-26-2009, 10:18 AM   #4
it was, but the original owners dug down deep enough to make it a cellar. there is no access from the inside of the house. the entire floor is concrete and the walls are cinder block.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Insulate joist bays along with radiant heat, how ? iMisspell Building & Construction 2 12-08-2008 01:17 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 07:07 PM
