How To Increase The Watts In My Solar Panel? - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 02-25-2010, 05:55 PM   #1
Question
How to Increase the Watts in my Solar Panel?
Hi, My nameís Ricardo and Iím from Mexico. Iíve a question.
I made a solar panel with 36 solar cells .5v and 3.5amp, that gives me a solar panel of 18 volts (12 volts) and 3.5 amps so the panel generates me 63 watts.
I would like to make a second solar panel, but my intention is to get more watts, I mean, increase from 63 watts to 126 watts. So I understand that if I connect 2 solar panels in series that will increment the voltage to 24 volts and I read on the Internet that is not good idea to do that because a lot of products work only with 12 volts.
So my question is: What I need to do if I want to have an output of 126 watts but with 12 volts? Should I connect my 2 panels in series or in parallel?
Thanks !
rdlrn19 is offline   Reply With Quote
Old 03-02-2010, 06:55 PM   #2
Thanks !
yes connect in parallel as many sets of 36 cells as you like as long as the charge controler can take the power
martin.rayner3 is offline   Reply With Quote
Tags
solar panel watts
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
sub panel for a big PC room. help 24,000 watts beast88mm Electrical 14 01-14-2010 05:44 PM
Solar Panel sneech Electrical 9 10-11-2008 06:27 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Solar panel for koi pond pump? Badfish740 Electrical 5 02-29-2008 04:29 AM
