Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Green Home Improvement
Old 02-10-2012, 09:40 AM   #1
home made solar panels
Instead of a glass front cover can thin stiff plastic be substituted?
openedHand is offline   Reply With Quote
Old 02-10-2012, 10:09 AM   #2
Lexan can be used but would have to be think enough so it would not sag.
Never use cheap plexaglass, it yellows, is effected by UV and will craze.
Old 02-10-2012, 05:12 PM   #3
Moderator
http://www.builditsolar.com/Projects.../sunspaces.htm
And, welcome to the forums!
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
EMD360 (06-15-2012)
Old 05-03-2012, 10:42 AM   #4
Excellent post, I have made all the panels that I use on my boat and a solar water heater. I have also made a water maker that works off of solar, it will produce about 8 to 10 gallons of water a day, just enough to keep the tanks full. I have also made a solar oven and dehydrator for food.
shanmarsh999 is offline   Reply With Quote
Old 05-07-2012, 09:20 PM   #5
Missouri Bound's Avatar
Twin walled polycarbonate works well, does not yellow and provides an insulation factor. Imagine a piece of corrugated (cardboard) but clear. I've used it for 15+ years and absolutely no yellowing.
Do you want it your way or the right way?
Old 05-17-2012, 10:44 PM   #6
What does a good piece of twin polycarbonate run in price?
C Alan Co. is offline   Reply With Quote
Old 05-17-2012, 10:53 PM   #7
Obviously it depends on the size. Check with Polytex, they are a greenhouse manufacturer.
Old 07-20-2012, 06:01 AM   #8
Solar oven. Very interesting. How did you do that?
garethcooper9 is offline   Reply With Quote
Old 08-14-2012, 10:06 PM   #9
Smile
ok, Guys,
How well are your solar panels working and how much of a savings have you realized after recovering cost of project?
Dana Lynn is offline   Reply With Quote
The Following User Says Thank You to Dana Lynn For This Useful Post:
edoy69 (08-20-2012)
home made scaffold saltysenior Building & Construction 12 11-01-2011 10:04 AM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General Discussion 24 05-19-2011 08:23 PM
Installing solar panels and need new roof cutieme Roofing 7 05-12-2010 10:08 PM
Solar Panels... House2488 Electrical 3 02-13-2010 01:14 PM
I want to go solar, need some advice! YerDugliness Green Home Improvement 3 01-20-2010 06:21 PM
