High Electric Bill - Green Home Improvement - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 03-13-2013, 12:02 PM   #16
Rewards Points: 6,652
Habits is the possible reason. Only way to get an idea of day to day use, is to hook up a Ted 5000 to your incoming lines on your main panel, and that will allow you to see what is going on. When we do laundry, run the dishwasher, have the home theater on, three tv's, we can see 44 to 55kwh on those days, rest of the time, about maybe 12kwh max.
Old 03-19-2013, 09:32 PM   #17
Rewards Points: 2,638
$170-200 seems high, but dividing that by 3 or 4 seems low. How many kWh/month do you use? I seem to use about 500-700 kWh/month in the winter. Everything is natural gas, but in the winter I don't worry about leaving the lights on, since the lights are all heat anyways.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Maxwell HVAC (03-21-2013)
Old 03-21-2013, 11:35 AM   #18
Switch over to hydrocarbon refrigerant in your A/C for the summer then watch the savings.
Maxwell HVAC is offline   Reply With Quote
Old 03-21-2013, 11:48 AM   #19
Is that legal?
http://www.epa.gov/ozone/snap/refrigerants/hc-12a.html
Old 03-21-2013, 11:58 AM   #20
Absolutely.
Old 03-21-2013, 12:06 PM   #21
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
I see potential problems with that. If I understand AC units correctly, they are designed for a specific refrigerant. Putting something other than what it is designed for could damage the equipment.
Without more specific information from the OP as to why type of system the OP has, the suggestion to put in a "hydrocarbon refrigerant" is pretty reckless and borders on being a backyard hack.
Old 03-22-2013, 02:48 PM   #22
Always learning...
fetzer85's Avatar
Rewards Points: 262
Can you check one of your recent bills and tell us how many kilowatt hours you used and how much you pay per kwh?
fetzer85 is offline   Reply With Quote
Old 03-27-2013, 08:26 AM   #23
Rewards Points: 774
Last bill was $170 and we used roughly 1900 kW....or just under 70 per day. Our cost was about $5.75 per day
cibula11 is offline   Reply With Quote
Old 03-27-2013, 09:00 AM   #24
So you are using 3 times as much enery as I am. Could be something like a pump that is always running, or a heater element that never turns off.
Old 03-27-2013, 09:08 AM   #25
Rewards Points: 774
Yep, three time as much as we used in our previous home too. We ran a space heater during a cold snap and figured that raised it by $30. I'm anxious to see with our warmer weather how much it lowers it because our furnace blower would run quite a bit during the winter.
Our sump pump runs quite a bit too, so that probably doesn't help out too much either. WE also have sewage ejector that runs once every couple of days, when we use the basement bathroom.
Any ideas what sort of heating element would be running continuously without me knowing?
Old 03-27-2013, 09:34 AM   #26
Where houses are heated by heat pumps, they normally have an electric heating element in it as a back up, for when it gets very cold outside. It has happened that the controls failed, and the heating element was on 100% of the time. Does not seem that this would be your situation, but what I am getting at is to look for something that should be running intermittantly, but is faulty and running continuously.
Old 03-27-2013, 11:54 AM   #27
Rewards Points: 774
Yeah, thanks.
Not sure what would be running continuously, other than a furnace....I would also assume we'd hear something running continuously. I'll keep checking.
Old 03-27-2013, 01:30 PM   #28
47_47's Avatar
Rewards Points: 58
Are you on a well?
47_47 is online now   Reply With Quote
Old 03-27-2013, 02:41 PM   #29
Rewards Points: 774
Originally Posted by 47_47 View Post
Are you on a well?
Yes and no. Our home is supplied by rural water and we have a horse barn that is supplied by a well. Nothing we use for ourselves in on well....just for livestock (which we don't have right now). I actually turned the all the shut-off valves to OFF so we wouldn't have any freezing.
Old 04-01-2013, 06:40 AM   #30
High Electric Bills
High electric bills here what we done to Stop it.
DIY SOLAR WATER HEATER SERPENTINE DESIGN
Raphael DIY
Ad removed
Raphael DIY is offline   Reply With Quote
high Electric Bill Cultcab Electrical 5 09-02-2012 09:21 AM
Electric Baseboard Heater Questions mark2741 HVAC 0 12-31-2010 12:08 PM
Unusually high electrical bill Henryjr General DIY Discussions 13 10-19-2010 08:05 AM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 09:25 AM
High electric Bill? HautingLu General DIY Discussions 9 08-28-2009 12:39 PM
