G4 Halogen Thin Bulbs To Replace With G4 LED? - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 03-04-2014, 01:59 PM   #1
Question
G4 halogen thin bulbs to replace with G4 LED?
hi everyone, does anyone know which brand type of LED G4 thin style/ flat style i can use to replace G4 halogen bulbs? and where to get such bulbs? have been searching all over without any success.
rocafella1978 is offline   Reply With Quote
Old 03-05-2014, 07:58 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
They have a 20 watt replacement at Lowes for $10 a pop. I have bought on eBay for about $3.
Coastal South Carolina
Old 03-05-2014, 08:35 AM   #3
A "Handy Husband"
rjniles's Avatar
Also be careful with what you buy. If these are 12 volt for landscape lighting, you need AC not DC lamps. Many of the cheaper ones on eBay are DC only.
http://www.ebay.com/itm/AC-12V-SMD-5...item27dca32e2e
Old 03-05-2014, 09:37 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
Try this place...
http://www.superbrightleds.com/searc...hold-bulbs/g4/
Old 03-06-2014, 10:26 AM   #5
Question
hi all, thank you for your help and guidance, i was looking to fit it indoors/ light fixture from ceiling in a room, and the current halogen G4 bulbs are Philips, see attached picture of them, specs are:
20W, 250lumens, G4, 12V, 2000hour bulbs, that's what i could read off them.
the reason is, because i have changed all bulbs in the house to LED lighting with 2700k color temperature, almost completely in the house.
problem is, all the LED i purchase from depot style of stores, and found, are just too large to replace the halogen, because the light fixture has glass covers which go over the bulbs, but the halogens are flat/ thin compared to the larger format/ thicker LED bulbs. so i am trying to find thin LED, size comparable to the halogen bulbs.
thank you all!
Old 03-06-2014, 10:30 AM   #6
A "Handy Husband"
rjniles's Avatar
That's the problem with small LEDs, due to the required electronics, they are larger than the Halogens.
Old 03-06-2014, 04:41 PM   #7
Oso954's Avatar
Rewards Points: 1,100
This is about as close as I think you will find, at this time.
http://www.ledwholesalers.com/store/...&productId=601
The color is a bit more white at 3500K
They will be a little less bright at 200 lumens.
There is a dimensional drawing at the bottom of the page.
Oso954 is online now   Reply With Quote
replacing fluorescent tube light with regular bulbs nikeman Electrical 7 08-07-2011 08:33 PM
Dimmable Fluorescent Bulbs hyunelan2 Electrical 6 04-26-2011 12:10 AM
using 60w incandescent bulbs in fan rated for 15w CFL denemante Electrical 13 03-21-2011 11:33 AM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Why use halogen lights instead of regular bulbs for outdoor lighting? darsunt Electrical 6 10-13-2009 09:58 PM
