Dyi Solar Panels Needed - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 10-02-2009, 01:47 PM   #1
dyi solar panels needed
i have purchased the greendiyengery.com soler guide and im looking where to buy the solar panles and the converter box and what ealse i need to hook the solar panles up to my house has eny one done this and where did they git the eguiment
b pahl is offline   Reply With Quote
Old 10-05-2009, 10:23 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
when you say "diy solar panels" do you mean you are looking to buy solar cells, and solder up a diy panel? if so, ebay is a good source for cells. If you are looking to buy completed panels for a diy system, you can get them from just about anywhere, including www.northerntool.com, www.homedepot.com, www.amazon.com,
As far as what else you need, it depends on what you want to do, and how big of a system you are doing.
the minimum you will need is:
1 panel
1 charge controller
1 battery
1 inverter if you want to run 120v stuff ( i assume this is what you mean by converter box)
misc wiring and connectors
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 10-07-2009, 06:03 PM   #3
Look at this spoof web site. It may be a spoof but it has a very serious message: http://www.diysolar.com/
I saw the photographs of the remains of a house the other day where the owner had fitted home-made solar panels on the roof. They shorted and caught fire and pretty much destroyed the house.
If you want to build your own solar system, use professionally manufactured panels. Due to the price drop in the industry over the past six months they're pretty much as cheap as building your own now and they all come with a decent warranty.
mboxwell is offline   Reply With Quote
Can you build your own solar panels? jpclark Green Home Improvement 4 11-29-2009 04:15 AM
newbe here, on solar panels WayneBlake Introductions 12 08-26-2009 05:23 PM
Questions about mounting PLYWOOD solar panels to a roof romesa Electrical 12 05-04-2009 09:06 PM
