Ceiling Fan Size Versus Distance To Wall - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 08-09-2014, 11:01 AM   #1
Ceiling Fan Size versus Distance to Wall
Hello! Sorry if this is the wrong section. I'm posting here because my entire purpose in this venture is to improve the effectiveness of my AC (read: to use the AC the same amount I use it now, which is roughly two hours a day, but make the house feel colder anyway).
I have a 1200 square foot townhouse and wish to put a ceiling fan in my living space, which is roughly 16x25 ft, with ceilings somewhere over 9 feet high. The problem is, I only have one existing electrical box, located off to the side of the room, and I'm not willing to have a second one added (I live in a co-op so would have to get board approval plus pay the huge Washington DC COL fees for an electrician).
The situation is this: The center of the box is approximately 37" from the closest wall. I can either get a 52" fan and only have a 10-ish inch space between it and the wall, or I can get a smaller fan and get closer to the "at least 18 inches" the internet recommends. What's better for my situation - bigger blades (for purposes of this discussion please assume bigger blades = higher CFM) or more space for the air to flow?
Thanks for your expertise/opinions!
e1sk is offline   Reply With Quote
Old 08-09-2014, 12:21 PM   #2
Oso954's Avatar
Rewards Points: 438
If you don't want to do it right, why do it ? You might consider a big box or pedestal fan instead.
You generally either center the ceiling fan in the room, or center it over the area where the people will be.
In a room of similar size at my house, I used two 52 inch fans to get really effective air movement.
The existing electrical box is not only in the wrong location, but it is probably not fan rated. So, it would need changing to a proper fan rated electrical box, if you were going to put a fan on it.
Oso954 is online now   Reply With Quote
Old 08-09-2014, 12:23 PM   #3
Thanks, Oso. I should add that other units do have ceiling fans in this same location and I know they didn't change any wiring. Again, it's a co-op... and not a permanent location at that. I'm not getting my money back if I go have the place rewired. And it'd take them until fall to agree to it anyway.
Do you have an answer for my question?
Old 08-09-2014, 12:54 PM   #4
Oso954's Avatar
Rewards Points: 438
If your neighbors did not change out the electrical box (not wiring), and the ceiling box is not fan rated, there is a good chance that one of these days the fan will fall out of the ceiling.
If you are happy with the performance of one of your neighbors fans, you can always buy a similar one.
Old 08-09-2014, 01:02 PM   #5
I obviously haven't gone and measured my neighbors' fans, nor have I monitored their change in energy consumption as a result of the fan.
I'm not asking a complicated question here - which makes a bigger impact, size of the fan or area around it?
Old 08-09-2014, 03:21 PM   #6
Oso954's Avatar
Rewards Points: 438
Since you are asking about the difference between 11" or 13" clearance (52" vs 48" fan) the larger fan should move more air. But, you are limiting the performance of either fan by pushing it too tight to the wall. The 18 inch recommendation is there for a reason.
Limiting the air flow on one side, may give you an unbalanced effect, particularly at high speed. It may be severe enough that you might not want to run it on high.
I don't think you will see any summertime savings with a fan jammed in there. If you do, it will be a placebo effect. Because you see it turning, you think it is cooler.
For a 16x25 foot room, I think you should have something close to a 72 inch fan, or two 52" fans (properly spaced) to see significant savings.
Tags
ceiling fan
new knee wall in existing cathedral ceiling rtoni Building & Construction 0 07-16-2013 05:52 PM
Figuring out CEILING JOIST size for 18' room span cloudburst51 Building & Construction 11 04-21-2013 08:58 PM
Removing a wall, how to support with a vaulted ceiling palabalo Building & Construction 9 04-12-2013 02:55 PM
Adding Ceiling fan without wall switch bennyhann Electrical 4 01-02-2012 04:19 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
