Carpet Under Vapor Barrier In Crawlspace Encapsulation? - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 02-20-2015, 01:59 AM   #1
Rewards Points: 106
Carpet under vapor barrier in crawlspace encapsulation?
Encapsulating a 14 x 28 crawlspace. Would like to use for storage. To protect knees and extend life of plastic, I'd like to unroll old carpet on top of the dirt before putting the plastic down. Is there any reason NOT to do this?
halliwellc is offline   Reply With Quote
Old 02-20-2015, 07:45 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,570
Yes. It will be a sponge. Vapor barrier needs contact with the soil or, at maximum, a smaller layer in between.
Is the soil level and free of sharp, puncturing rocks?
Carpet should go on top.
Old 02-20-2015, 01:11 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 2,674
Also the carpet would grow mold and would stink.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 02-20-2015, 02:07 PM   #4
Rewards Points: 106
Dirt in this crawlspace is bone-dry and at grade. It actually needed to be wetted to keep dust down for leveling. 4 feet tall, will be used for frequent storage, I'm hoping to save my knees and protect the plastic. 16 mil plastic. Dirt is raked, free of rocks, just want more protection.
Even if the carpet did grow mold and stink, why would it matter? Wouldn't it be encapsulated away? It's old carpet, would prefer not to smell or see it, under plastic seems like a good idea.
Old 02-20-2015, 05:25 PM   #5
Use landscape fabric and you can double it over. Then put the plastic over it, then the carpet.
Old 02-21-2015, 11:14 PM   #6
Registered User
Rewards Points: 2,614
"encapsulating it"- are you sealing the crawlspace vents? IF so, you need to supply air from the house to rid it of moisture build-up. Crawls track the ambient air relative humidity. 5 choices; http://www.google.com/url?sa=t&rct=j...59026428,d.cGU
Gary
WELCOME to the forums, if I forgot to say it!
Crawlspace encapsulation complication halliwellc Building & Construction 2 12-17-2014 07:21 PM
Crawlspace Encapsulation and HVAC amg1950 HVAC 0 10-22-2013 08:11 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 12:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
