Building Green On A Budget Suggestions - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 12-05-2008, 07:51 AM   #1
When is fishing season?
CowboyAndy's Avatar
Building green on a budget suggestions
I am on the board of directors for our local Habitat for Humanity and would like to propose that our next house be "green". I dont know a whole lot about building green, so i'm looking for some suggestions. Budget s a big concern.
Any ideas?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 12-16-2008, 09:26 AM   #2
home improvement guru
aaron.klimchuk's Avatar
here are a few articles I found which might be able to help you out...
http://www.content4reprint.com/home/...ower-plant.htm
http://personalitydisorders.suite101...efficient_home
http://www.associatedcontent.com/art...form_your.html
aaron.klimchuk is offline   Reply With Quote
Old 01-09-2009, 09:41 PM   #3
Green costs money. Can't be on a tight budget and be green also. That might happen one day but that day is not here yet?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 01-16-2009, 09:19 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
not true there are alot of ways you can build green that aren't necessarily more expensive check out green builder magazine or mother earth news you just have to have the proper mind set and be open to ideas dont let anybody tell you its too expensive
Tom Struble is offline   Reply With Quote
Old 01-16-2009, 10:38 PM   #5
concretemasonry's Avatar
Rewards Points: 2,594
Habitat relies heavily on donations from suppliers.
You might get something from some "green" suppliers for one house or two to get quick publicity, but Habitat will not risk future donations from other long term suppliers.
It is a political tight rope to walk.
concretemasonry is offline   Reply With Quote
Old 02-17-2009, 01:48 PM   #6
Green can be done on a budget. Green isn't only about PV Solar and wind turbines.
Low/No VOC paints like Fresh Aire. It's about $10 more per gallon.
Bamboo flooring / Stained concrete flooring
Low Flow Shower heads and sink aerators (My shower head cost $10.00)
Low flow toilets
Cellulose insulation rather than fiberglass
Compact flourescent light bulbs
Ceiling fans
Solar tubes
Hardie Planking exterior (which every Habitat house I've worked on used)
Passive solar design utilizing correct exposures and windows for air flow
Concrete or tile counterops vs laminate
On demand water heater
Drought resistant landscaping
Use Fly Ash concrete
Recycled ceramic tiles from Crossville cost about $4/sf
One of the best things I've seen: a single switch that shuts off every phantom electric item in the house with one flick. Things like coffee makers, cell phone chargers, etc. Things that are on even when they're off.
We worked on the Jimmie Johnson/Habitat house here in San Diego last summer and they did have a donation of PV solar and the house is set up for net metering.
We worked on Habitat houses on the San Carlos reservation after the wildfires and several of the houses were built using ICFs.
GreenSD is offline   Reply With Quote
Old 02-17-2009, 04:02 PM   #7
Registered User
Termite's Avatar
Originally Posted by homecarecentral View Post
SIP's structurized insulated panels, are cheaper than traditional building methods...
I'm a huge fan of SIPs and advocate their use, but that just isn't true. I'm sure it varies somewhat from region to region, but around here when compared to conventional framing methods, the materials and labor costs of a SIP home will be 25% higher than the stick built home. That is a lot of money that would take years to recuperate in energy savings, although a SIPs house with 6" walls gets something like R38, which is nice.
Old 03-11-2009, 11:34 AM   #8
JMD
These would be my suggestions:
Try looking into using different building techniques to reduce waste. Maybe a framing technique that requires less material while still being code compliant.
Make sure you are insulating properly, sealing ductwork tightly and sealing the building envelope properly. This can result in using less energy to heat/cool the home.
Try to use local products to reduce polution caused by transportation. This isn't just buying from a local store but for example getting wood from locally grown trees, milled locally, and from a local distributor. Easier said than done.
Finally try to reduce waste as much as possible. What was you end up with try to recycle or use on another project.
Building green does not necessarily have to be the products you use. Look to conserve or be more energy efficient in areas that may not affect your budget. Also make sure that the little things are done right. Not sealing the ductwork properly can lead to innefficiencies in your HVAC system. Not cauling propery and failing to seal penetrations can lead to air penetration that will make your HVAC system work extra hard to cool the outdoor air.
JMD is offline   Reply With Quote
Old 04-17-2009, 08:46 PM   #9
Learning by Doing
Leah Frances's Avatar
Ok, how do I get one of those? I would love to stop unplugging my toaster every day.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-18-2009, 10:22 AM   #10
Wethead's Avatar
Any ideas?
make sure the house has a fireplace.
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Green is the New Black aaron.klimchuk Green Home Improvement 36 02-17-2009 09:07 AM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 04:47 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
