Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Green Home Improvement
Old 05-26-2010, 07:36 PM   #1
Balancing wind generator
I'm nearly finished with my wind generator. The blades are nicely balanced. The body however is much heavier on the rotor side than on the tail section. Is this a problem? How much strain can the unit take?
Help!!
Unclebob
Last edited by Scuba_Dave; 05-26-2010 at 08:29 PM. Reason: removed advertising links
unclebob is offline   Reply With Quote
Old 08-02-2010, 11:32 AM   #2
VBT
VBT's Avatar
Usually on a horizontal wind turbine you control the stress on your assembled unit by placing your mounting point at the balance point of the unit. If the balance point is too close to the front of the unit to make this practical you may have to add some balancing weight to the tail section until it is practical.
Having stress on the the front end due to it being too heavy as compared to the tail section can cause all sorts of problems leading to jamming or eventual failure of your mounting bearings.
VBT is offline   Reply With Quote
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
i need help...wind generator! alaa Electrical 3 04-15-2010 10:36 PM
building a wind generator jumptruck Green Home Improvement 4 11-04-2009 10:38 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
