Attic Solar Fan - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 06-18-2015, 11:23 AM   #1
Rewards Points: 90
Attic solar fan
Are attic solar fan worth the hype or is is a big marketing scheme with possible roof future leakage?
My attic has 8 easel and about six 6x6 vents at the top. Yet the attic reaches high temperatures here on a texas summer. To reduce my energy bill, wanted to know if an attic fan would be worth the investment or a waste of time.
Should I focus on more insulation and sealing the attic or make the investment on getting a fan first and then reinstating the attic?
I am only finding a lot of marketing info online and wanted to ask the pros for some guidance. I will eventually do both, but wanted to see if anyone just only put an attic fan and wanted to know what significant did they experience by just adding the fan. That would help in the deciding side of things.
Thanks in advance.
jesusq is offline   Reply With Quote
Old 06-18-2015, 12:36 PM   #2
Oso954's Avatar
Rewards Points: 1,654
I would suggest that you get a pro to review your attic venting.
Often multiple vents on the roof are a sign of people adding vents hoping to improve the situation. So they can be a sign of other problems such as not enough (or large enough) soffit vents for air entry.
A common problem with power vents (solar or not) is locating them too close to another roof vent. You can end up pulling fresh air in the exhaust vent and have it exit the power vent, while leaving most of the overheated attic air undisturbed.
Oso954 is offline   Reply With Quote
Old 06-18-2015, 01:35 PM   #3
Rewards Points: 90
If that's the case, a fan would be a waist. I have 8 easil on the lower attic and about three vents on the top of the attic. If that's the case, I can convert one of the vents to a fan. But would there be any significance to adding a fan?
Old 06-18-2015, 03:59 PM   #4
Rewards Points: 222
My parents have an attic fan, but they don't have air conditioning. From what I can tell, their attic fan works generally well. Their attic gets crazy hot and sucking out the hot air helps to keep the house cool.
I think the major factor for getting an attic fan is that the air outside the house must be cooler than the air inside the house. Basically, hot attic air gets pushed out through the attic fan and that sucks air from the house into the attic. This sucks the cooler outside air into the house the house through the windows. And the house feels cooler
If the air outside the house is just as hot inside the house, then it doesn’t make much difference.
One additional thing is that my parents' attic fan is solar powered and it need direct sun to work. So when the sun goes behind a cloud or moves to the other side of the house, the fan stops spinning and that's not ideal.
From what I've read if you have air conditioning, an attic fan may not reduce your cooling costs.
LeakyHawaiiRoof is offline   Reply With Quote
Old 06-18-2015, 05:22 PM   #5
Rewards Points: 90
My though is that if I insulate the attic and remove the hot air by placing a fan, my thought would be that the air condition won't have to work as hard to keep the house cooled.
Now my questions is how much easle and vent is too much or too little for an attic fan to be effective or a waste of money and time?
What do you go by to decided if an attic fan would be effective?
Old 06-20-2015, 12:27 AM   #6
Registered User
Rewards Points: 526
http://www.greenbuildingadvisor.com/...tilators-green
http://www.ronhungarter.com/black_mold.html
http://www.fsec.ucf.edu/en/publicati...SEC-GP-171-00/
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Windows on Wash (06-23-2015)
Old 07-15-2015, 12:50 PM   #7
Rewards Points: 52
I had an existing gable vent and I retrofitted a 20 watt solar fan and thermostat. It made a substantial difference in the amount of heat in the attic. I took it a step further by putting in an insulated radiant attic barrier and I no longer have issues with cooling my house. I've been kicking myself that I didn't do it sooner and have been needlessly sitting in a house that the temperature ran 8 degrees above the set temp in the summer. It turned out well, and I'm glad I did made the upgrade. Hope this helps!
jayp526 is offline   Reply With Quote
Old 07-20-2015, 12:01 PM   #8
Rewards Points: 5,336
[QUOTE=LeakyHawaiiRoof;2172953]My parents have an attic fan, but they don't have air conditioning. From what I can tell, their attic fan works generally well. Their attic gets crazy hot and sucking out the hot air helps to keep the house cool."
What you're describing is a whole house fan. It may be in the attic but it's not what the OP is talking about.
He's talking about an attic exhaust fan that expels super heated air out of the attic while pulling in outside air to replace it.
It's restricted to the attic space for the most part due to leakage in construction.
Ron
B. Franklin 1759
Old 07-24-2015, 07:10 AM   #9
craig11152's Avatar
Rewards Points: 376
There is a general rule of thumb in the industry that one should not mix and match various types of exhaust vents on a roof. This is particularly important if there are functional soffit vents. The idea is that air will follow the path of least resistance and some exhaust vent will become an intake for another exhaust vent and they aren't designed for intake. If one subscribes to that theory then a solar fan doesn't really fit in well to "balanced" venting.
Don't look at me. I didn't vote for either one of them.
craig11152 is online now   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
Solar attic fan? stevemr Roofing/Siding 1 06-26-2005 05:35 AM
