Anyone doing any solar projects?
I admit this might not be the best spot for this but then the board machinery would have had to allow me to send a PM to ask someone about it :001_tongue:
I looked around and didn't see a category or conversation on any solar DIYery, did I just overlook it? I have been mulling it over (a good part of my winters are spent honing my mulling skills) and I am considering fabricating my own lil low-tech solar heater assy. Some ready research (thank you internet!) has coughed up some good ideas on fairly simple/ fairly inexpensive solar hot air collectors. We have a southern face on our house that gets sun all day and could gather a substantial amount vented to a rockbox in the crawlspace, convection heating from there into the house, etc. Anyone here doing anything similar? I'd really be open to any input on mistakes to be avoided and interesting ideas to optimize the operation. |
there is a green home improvement forum HERE,
My landlord has a few square feet panel on his garage roof. It's hooked up to three car batteries, wired in parallel, powering a simple high wattage inverter. I think he got it at Grainger, where they also have huge batteries. He just putters around but he can fire up a power tool anytime he wants. On demand power is only limited by the capacity of the battery bank. Available power is just limited by square footage of panel and a little thing called the sun.
I want to get into solar at some point, but panels arnt cheap. Would take a while to make up the cost. But guess when going green,it's more about just saving money, it's to actually help the environment. Hard to justify when your power comes from hydro dams though. :P
I've been leaning toward wind because I'm impressed at what a small turbine attached to your house can do in comparison to a much larger solar panel array. I was under the impression that noise would be a factor until I saw small ones attached to houses right in the middle of town that were inaudible from the street.
I've thought about wind too, and it's much cheaper as you can make your own turbine. I like the concept of the vertical turbines as the motor can be stationary and makes the wiring easier.
Solar only really works when the sun is out. At this time of year that might be like 2 hours a day in average, while wind is quite constantly present day and night. |
Check out the links on this site.
energy21 free energy website Encyclopedia of Free energy, Australian energy21 website search engine. www.energy21.freeservers.com - View by Ixquick Proxy |
Well, I wouldn't do photovoltaics (sunlight to electricity). Sunlight doesn't convert to electricity well, the photovoltaic panels are typically only 11-14% efficient, the rest of the energy turns mosly into heat which is bad for photovoltaics the hotter they get the less efficient and less electricity they make.
What sunlight does convert well to, is heat. I'm sure you've left a tool in the sun and felt first hand how well it converts to heat. Solar panels that run fluid through them are typically in the 75-80% efficient range, air is not as efficient for transferring the heat. I'm not sure what you were thinking of doing, I've heard of drilling out the tops & bottoms of soda cans, stacking them one on top of the other, painting them black, and putting them in an insulated case with air blowing in the bottom when the sun is out (cansolair I believe is exactly this). But, I find home made systems typically look terrible. I don't know why you'd make one that uses air, and blows it over rocks instead of one that runs fluid and stores the energy in a water tank. Solar air methods aren't as efficient as hydronic, and in summer what are you going to do with a solar air heating system? At least if you heat fluid and store it in a tank you can use it as a pre-heater or use it exclusively for your hot water needs in summer. Just something to think about. And I would get real solar panels (with pipes running through them) not build your own. It was home made jobs in the 80's that failed prematurely from the high temps that almost killed the solar industry. Fiberglass faces clouded and etched in the heat, wood frames expand and contract so much the nails & screws eventually failed to hold them together. Sealing it in a sufficient way against the intense sun of summer is very difficult, and any leaks means condensation. Get yourself a real panel, even a used one if you have to I wouldn't try to build one yourself. I did solar recently for just hot water. I purchased a kit, with the rebates I got afterward I think it cost me the same in the end as going out and buying all the components seperately and trying to build it from scratch. But, I don't get rebates doing it that way. I ended up with a professional system I installed myself, for the same price as probably trying to make one from scratch. |
There are tons of ways to green up your house, even to the point of paying little to no utility bills! :thumbup:
I also saw on another forum how a man built his own solar panel using recycled aluminum cans. I am sure if you google it there is a set of instructions floating around the internet... I am also interested in the wind turbines, but be careful, a lot of trigger happy communities banned them for fear of noise etc. when they were just becoming popular. check with your neighborhood and township before you start that big project. and if they don't allow it, become an activist and get the rule changed! :yes: |
I've thought of solar panels but their watt / dollar is a turn off. I would want at least 1 kw of power out of any solution, that way at least I'm more or less powering the whole house, and only need excess during small time periods, like if I need to use the stove or dryer.
Though with hot water, has anyone used it to power a sterling engine to then get electricity that way? Is it more effective then just solar cells? There is some loss of energy when going from heat to movement, but is it significant? |
I have 8 old solar panel boxes....not much would be of use except for the metal collector "sheet" and the glass, but I wouldn't mind experimenting some when I have time. Who knows, this might just make a big difference in a small structure that is off the grid. Cheers from Dugly :cool: |
I keep dreaming of installing solar panels here but I am glad I've read your post. Thanks for taking the time to write it. |
Keep the FREE heat
ThatDaveGuy,
If you have the South Facing wall and a few tools. I say, why not? Even if you don't get it perfect the first time, you're going to learn something and create some free heat. My thoughts about storing the heat in a thermal mass in your basement... Insulate your Basement If you don't air seal and insulate your basement, all the free heat is going to disappear through the walls and holes in your foundation walls before it rises up into your living spaces upstairs. |
Solar Air Furnace Plans
BTW - If you are looking for plans or guidance in building a solar air furnace...try this site. http://builditsolar.com/Projects/Spa...ce_Heating.htm
According to this site, solar space heating is 25 times more efficient than solar electricity. Especially if you DIY, |
I've been working on a few ideas based on propylene glycol
| All times are GMT -4. The time now is 06:27 PM. |
