Any Thoughts On Using Attic Heat? - Green Home Improvement - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 08-11-2012, 10:22 AM   #16
Rewards Points: 95
Originally Posted by SPS-1 View Post
Perry, your signature says you are in Florida.
I wouldn't think a house needs much heating, in Florida, in August.
I am in Canada, and I have had my furnace switched off since May.
Right! But I'm at 51.72 or thereabouts at the moment, on holiday.
Perry525 is offline   Reply With Quote
Old 08-12-2012, 01:12 AM   #17
Originally Posted by Perry525 View Post
It is controlled by two temperature sensors one in the roof switches on when the inside roof temperature moves above 74F/23C, the other in the lounge switches on when the temperature in the lounge drops below 74F/23C. With both on, the fan runs.
Where did you get the switches? I will be doing something similar but can't seem to locate the simple snap action temperature switches suitable for this. You can get these complex and expensive user adjustable switches for the DIYer but I don't trust them. I'd rather just order the simplest switch available that operates at one temperature that you specify when ordering. Less to go wrong.
Exeric is offline   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
why the Heat Pump - Attic Unit Vibrate? DaveA HVAC 1 01-27-2011 11:29 PM
Idea for attic insulation baffles. What are your thoughts? Ininkus Building & Construction 8 02-26-2009 01:46 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
hot water heat attic central air...hot basement in summer spttrac214 HVAC 2 02-29-2008 06:24 AM
