$700 Lowe's Patio Door Or $3000 Andersen Door? - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 08-04-2010, 09:09 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
$700 Lowe's patio door or $3000 Andersen door?
I'm in the process of building a deck off the back of my house. There's a window there right now - when the deck is done we plan on putting in a sliding or swinging door.
My house is from 1930 and the windows are original. They are in good shape, but they are ... from 1930! Eventually I'd like to start replacing them but it'll be years before I get to all of them. Do you think it would be worth it to buy a fancy Andersen door or would you stick with whatever Lowe'd or HD has? (they seem to be in the $700 range)
CoconutPete is offline   Reply With Quote
Old 08-04-2010, 10:43 AM   #2
Rewards Points: 558
You can get a pretty decent door at either of those places. Besides who is going to see your new fancy Andersen door in the back yard? But if you up grade to good windows then everybody will notice them.. just make sure that before you order your doors and or windows you have your rough opening correct
epson is offline   Reply With Quote
Old 08-04-2010, 11:15 AM   #3
I bought a Pella slider from Lowes
Within 2 years the alum "molding" was pulling awya from the glass
Old 08-05-2010, 09:32 AM   #4
Rewards Points: 504
I just meant buying an energy efficient door would cost more but be a moot point until the windows were replaced too - wasn't really worried about people seeing it
So do would you recommend buying a wooden one? I was eyeballing a few.
Old 08-05-2010, 09:38 AM   #5
The pella actually has wood on the inside
One reason I wanted it is that the screen is on the inside
The andersens are more $$
My front door is Therma Tru - which I like
Old 08-05-2010, 02:04 PM   #6
gmhammes's Avatar
If your going to be doing work to the house for years to come i would put a standard sliding door in. If your rough opening is standard, odds are you can upgrade your door later with minimal work.
gmhammes is offline   Reply With Quote
leaking patio door jpg274 Building & Construction 2 10-30-2009 04:42 AM
Patio Door installed incorreclty? whitek Building & Construction 4 09-03-2009 08:07 AM
10-12' wide patio door installed gregoryedgar Building & Construction 2 06-02-2006 07:57 AM
Aluminum patio door removal yeterp Remodeling 2 11-09-2005 12:49 AM
french patio door replacement nasa-hvac Building & Construction 2 06-15-2005 09:49 AM
