Yuk! Shingle Packaging Is Awful! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-24-2007, 09:02 PM   #16
Rewards Points: 258
Augie, No overlay. Complete strip off. I wanted to see what was under there, and I thought it would look cleaner. I thought I had a leak up on the ridge/rake area. Turned out not to be a leak. Just a busted up 20" x 48" piece of sheathing from (we think) tree limb piece. Thats the only piece replaced. Don't buy replacement sheathing until you see what you need. I now have 2 sheets of CDX in the garage I didn't even use. I'm very happy though. I can see why roofers in general like GAF. Go's on quick, not a lot of stones to slip on. Not the prettiest roof, nor the most 3D high definition looking. Very demur, unassuming, and monotone in nature.
Now Elk on the other hand to my eye is the best looking. Was my first choice. But, I had to consider what was really most important long term. My roofer is very "at home" with GAF. Says never had a issue with it since the early 90"s.
ELK, on the other hand has just to many negative comments on the board and else ware. I just didn't want to risk it.
Actually, I have a friend who did use the prestige 50yr ELK. It did not come out the way he thought it would. He thinks it is a roofer issue. I'm not so sure.
Docfletcher is offline   Reply With Quote
Old 08-24-2007, 09:57 PM   #17
Rewards Points: 398
Originally Posted by Docfletcher View Post
Augie, No overlay. Complete strip off. I wanted to see what was under there, and I thought it would look cleaner. I thought I had a leak up on the ridge/rake area. Turned out not to be a leak. Just a busted up 20" x 48" piece of under layment from (we think) tree limb piece. Thats the only piece replaced. Don't buy replacement under layment untill you see what you need. I now have 2 sheets of CDX in the garage I didn't even use. I'm very happy though. I can see why roofers in general like GAF. Go's on quick, not a lot of stones to slip on. Not the prettiest roof, nor the most 3D high definition looking. Very demur, unassuming, and monotone in nature.
Now Elk on the other hand to my eye is the best looking. Was my first choice. But, I had to consider what was really most important long term. My roofer is very "at home" with GAF. Says never had a issue with it sinve the early 90"s.
ELK, on the other hand has just to many negative comments on the board and else ware. I just didn't want risk it.
I thought the exact same thing. I think Elk looks the best, and I didn't go with GAF because of how bland it was. I ended up going with OC. I think their higher warranty shingles look pretty good.
Malcolm is offline   Reply With Quote
Old 08-24-2007, 10:18 PM   #18
Rewards Points: 258
Were you able to take advantage of the 25% off sale at Lowes which they had recently?
My roof slope does not allow for the finest display. Still looks much nicer than 3 tab.
Old 08-26-2007, 09:07 PM   #19
the roofing god's Avatar
Send a message via MSN to the roofing god
DOC, underlayment is ICE+WATER SHIELD ,Felt paper,or Base sheet,wood decking is referred to as roof sheathing
the roofing god is offline   Reply With Quote
Old 08-26-2007, 09:30 PM   #20
Rewards Points: 258
Whoops, sorry my ignorance shows. Thanks for setting me straight. I will not err in such fashion again.
Augie, earlier I referred to under layment replacement when I should have said roof sheathing. The only place I had under layment on my roof was at the eves.
Old 08-26-2007, 09:43 PM   #21
Custom Cabinet Maker
"the Roofing God" Once again Doc did not display the proper attitude
His PROPER RESPONSE SHOULD HAVE BEEN:
ROFLMAO
skymaster is offline   Reply With Quote
Old 08-26-2007, 10:21 PM   #22
Rewards Points: 258
Old 08-26-2007, 10:46 PM   #23
I thought I might be being too nice
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 09:05 AM
Comp shingle recommendations needed Arndavis Roofing/Siding 7 06-07-2008 09:01 PM
CertainTeed starter shingle ? MACCC Roofing/Siding 2 04-20-2007 02:26 PM
Shingle Pattern gilberte Roofing/Siding 7 09-05-2005 03:37 PM
Disconinuted Shingle nlcotten Roofing/Siding 8 03-22-2005 09:15 AM
