Wrong Slant To Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-18-2014, 02:27 PM   #1
Rewards Points: 154
Wrong slant to gutters
I just got a new steel roof and steel gutters. I forgot to mention to the roofers that the edge of the roof was slanted the wrong way for the location of the one downspout and none of the installers noticed. So I have one inch of standing water on one side of the 30' gutter.
Moving the gutter up is not an option at this time since the steel roofing overlaps the gutter and is tacked in with ring shank nails. I would cause a lot of damage trying to remove them.
I would rather not add a second downspout, since its location would be next to the front entry, hosing down shoes as people walked in, or tripping over a pipe if I tried to redirect it.
Someone has suggested flowing hot tar in the gutter to get the slope I wanted. Has anyone heard of this method?
How much will the standing water reduce the life of the steel and caulked seams? That is, should I be worried about this at all?
ovahimba is offline   Reply With Quote
Old 02-18-2014, 03:41 PM   #2
Rewards Points: 2,064
Gutter installers can't change the slope of a building even if they did notice or you mentioned it. I wouldn't be concerned about longevity and if it did rust away in possibly 5-10 years replace it with continuous aluminum.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Windows on Wash (02-18-2014)
Old 02-18-2014, 04:09 PM   #3
Rewards Points: 14,306
Remove and reslope the gutter.
Old 02-18-2014, 04:14 PM   #4
Metal Roofing
Rewards Points: 600
Steel or Alum?
Surely in your location they are Alum, are you sure they are steel?
You have two options at this point, either add a down spout or do nothing.
Depending on the roof type it could be moved up, you didn't specify what roof you have though.
AndyWRS is offline   Reply With Quote
Old 02-18-2014, 05:00 PM   #5
Rewards Points: 154
I don't like the tar idea. It will reduce the holding capacity of the gutters and possibly impede the flow of water.
eharri3 is offline   Reply With Quote
The Following User Says Thank You to eharri3 For This Useful Post:
joecaption (02-18-2014)
Old 02-18-2014, 08:52 PM   #6
Rewards Points: 154
Thanks for the replies. I posted some photos below.
The gutters may well be aluminum. The metal is a lot thinner than the 25 year old gutters that were removed and I didn't see any galvanized finish.
The roofing is stone coated steel. The stuff is barely thicker than tin roofing, so if you put a nail remover against it, you would destroy the material and certainly the sand coating.
The roofers were shimming the battens in many places on the roof, so I'm sure it wouldn't have taken them much time to adjust the slant if I had mentioned it.
It was actually the building inspector that told me about the trick with tar. I assume he has seen a lot of stuff. The gutters are 6" deep so there is plenty of space to work with.
Wrong slant to gutters-img_0874s.jpg   Wrong slant to gutters-img_0844s.jpg   Wrong slant to gutters-img_0856s.jpg   Wrong slant to gutters-img_0912s.jpg
Old 02-18-2014, 10:53 PM   #7
Davejss's Avatar
Rewards Points: 782
I don't know about you but I always water test my gutters. I snap a line with the appropriate pitch and temporarily tack the gutter in place. Then I dump in a bucket or two of water and test the flow. Adjust if needed then complete the install.
If your guy didn't do it right, don't pay him until he fixes it.
Creating pitch with tar is a very old, tried and true technique that was used back in the days of wood gutters. It will work with aluminum too I suppose.
Davejss is offline   Reply With Quote
Old 02-19-2014, 08:03 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Nice looking roof.
Decra shake?
Came out really nice.
Old 02-19-2014, 09:57 AM   #9
Rewards Points: 154
Yes that's Decra shake.
If only they had used screws to attach that last course of tiles to the gutter, then it would have been simple to take off the gutter, add strips of wood to correct the pitch, and reattach.
I can't count the number of times I was easily able back out a mistake because I used screws over nails.
Old 02-19-2014, 02:47 PM   #10
Metal Roofing
Rewards Points: 600
It surprises me to see that going on with ring shanks still.
Those tiles can be removed with a ring shank in them, if your care full with the cats paw and then follow up with the touch up kit...its been done 1000s of times. Room additions, skylights, solar tubes ect... all require the roofing to be modified and screws are just the way to go.
If I knew the gutter could be re hung to solve this I would pull the nails from the first row only. Not the nails at the back of the first course, just the top nails on the first course near the gutter. You should have enough play in the tiles to re-hang the gutter at that point. Id put it that last course back on with screws in the existing holes...then touch up with the kit provided. If I felt that wasn't going to work, then I'd add a down spout.
Old 02-19-2014, 04:26 PM   #11
Rewards Points: 808
Since the gutter is aluminum there's no worry of rust. 1" of standing water? I'd let sleeping dogs lie. That'll evaporate out during 1 sunny day.
IslandGuy is offline   Reply With Quote
Old 02-20-2014, 06:55 AM   #12
I am not sure the gutter is worth addressing either if the pitch offset is minimal.
We always screw in our Decra for just those reasons you mentioned.
Good looking roof though!
Old 02-20-2014, 01:54 PM   #13
Tom Struble's Avatar
Rewards Points: 2,002
whats with the closest pipe flashing?and were are the hanger for the gutter?what holds the front edge?
Tom Struble is offline   Reply With Quote
Old 02-20-2014, 06:54 PM   #14
Metal Roofing
Rewards Points: 600
It appears to also have the "wrong slant" could just be the camera view.
I think I see a spike in the gutter on the far left or maybe its a hanger I cant tell.
The front edge of the roof does appear to not be fastened also. Unless they nailed it through the nose and the gutter cover is obscuring it. Typically the first row is fastened with a screw down through the top of the tile into the 2x2...or nailed.
The Following User Says Thank You to AndyWRS For This Useful Post:
Tom Struble (02-20-2014)
Old 02-21-2014, 10:22 AM   #15
Rewards Points: 154
I posted a few more photos
The inner lip of the gutter sits on top of the 2x2 attached to the top of the fascia board. Then the edge of the roofing wraps over the inner edge of the gutter, held in place by ring shank nails.
I wasn't there when they installed the pipe flashing so I'm not sure of the details, but the contractor assured me caulking wasn't the primary defense.
How do you tell if its aluminum or steel? Does it make different sound when you tap it? Does it scratch differently? I thought steel would have been thicker material but maybe not.
I'll leave things as is for now. But later if I ever want to remove the gutter I'll use a tool generally not available to the public. I'll rig an adapter to my portable compressor so I could use my dental drill. Its not really a drill but an ultra high speed router which can obliterate those nail heads. It might cost several hundred in bits and maybe a burnt turbine but everything would come off with no damage.
Wrong slant to gutters-img_5055s.jpg   Wrong slant to gutters-img_5061s.jpg   Wrong slant to gutters-img_5062s.jpg   Wrong slant to gutters-img_5067s.jpg   Wrong slant to gutters-img_5068s.jpg
Heat for My Office - Slant Fin baseboards? Slant Fin "The Kicker"? Runtal? spta97 HVAC 50 02-25-2014 04:14 AM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 09:23 AM
Gutters and Decorative Trim on Fascia paulyg Roofing/Siding 12 07-27-2010 02:54 PM
leaf free gutters icicles and ice dams bluemetro Roofing/Siding 16 02-23-2010 09:14 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
