Wrapping Facia - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-10-2014, 07:04 PM   #1
wrapping facia
Can somebody give me some advice on this. I had new gutters and soffits put in. I also had the facia board wrapped in aluminum.
The situation is the soffit rests about an inch above the bottom of the facia board. The facia wrap was installed under the drip edge, down the front of the facia board, bent 90degress under the facia board and angled 45 degrees upward to meet the soffit. My concern is this installation creates a channel for moisture to accumulate and eventually rot the facia board. The contractor says there is no way for moisture to get in. I see it differently. Besides, what happens if I have to clean the exterior of the house? there will most definitely be water getting in.
Is this install done correct?
emmsvs is offline   Reply With Quote
Old 04-10-2014, 09:52 PM   #2
Rewards Points: 12,886
Second post and still no picture.
No clue why there's a 45.
Old 04-11-2014, 10:35 AM   #3
firehawkmph's Avatar
Rewards Points: 1,800
I've seen soffits wrapped that way around here many a time. The reason they do it is the extra bend makes the wrap a little stiffer so to eliminate any rippling. I don't do it that way. I poke it up under the drip edge, come down the fascia, then have a 1" wide bend that is slightly more than 90 degrees, which helps it hug the soffit. Doesn't trap water and holds up fine.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
joecaption (04-11-2014)
Old 04-11-2014, 12:29 PM   #4
Rewards Points: 2,238
Wrapping fascia the way "firehawkmph" describes :
We've been doing that for 35+ years.
Haven't seen problems with the wood, sub-fascia rotting out.
If you've got water getting to the wood -
Water -
Gutters, roof-edge, no "Water-Shield" - bad; or, failing roofing -
ventilation......
All kinds of problems!
rossfingal is offline   Reply With Quote
Old 04-11-2014, 12:35 PM   #5
Coil stock slid in behind the drip edge and I punch small oval shaped holes in the bottom seam with a special punch so the only nails are on the bottom, not the face.
So it looks better and the material can expand and contract without buckling.
Old 04-11-2014, 06:44 PM   #6
Thanks!
Old 04-11-2014, 07:13 PM   #7
You're Welcome!
(From all/any of us!)
The way they did it should not be a problem!
Facia on mono truss yamsicle Building & Construction 2 08-31-2012 01:27 AM
Pipe need to be dry when wrapping teflon tape? thisisbrianly Plumbing 5 09-27-2009 10:29 PM
Repairing facia and roof edge hollerg Roofing/Siding 2 03-03-2009 01:51 AM
Best replacement Facia Bigbobdallas Building & Construction 6 06-19-2008 01:09 PM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 06:01 PM
