Would Gutter Apron Support Weight Of Shingles? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-10-2010, 10:13 PM   #1
Would gutter apron support weight of shingles?
On a stretch of eave where there is no flashing at all yet, the roof deck is higher than, and back from, the fascia. If gutter apron rises straight up from fascia front then back (on an angle) to roof deck, it would have to hold up shingles for a space. The gutter aprons I've seen offered on the internet are not particularly heavy gauge. Could they support shingles for an inch and 1/2 or so?
A local animal control company could install a very heavy duty aluminum flashing that is made especially for them--the same angle as regular gutter apron but with no kick-out at the bottom, and no flexibility. It would certainly hold up shingles and keep out squirrels as well, but I've read that the lack of a kick out would pose a problem of capillary action for water. Also, with no flexibility, I'm thinking it might not be good if the angle of the roof is different from the angle of the flashing.
The only other local source of gutter apron that I know of is Home Depot, and I think theirs is both relatively light gauge and lacking a kick out.
Advice?
Thanks.
Sophie
sophie10 is offline   Reply With Quote
Old 11-10-2010, 10:53 PM   #2
I'd say yes.1/2-1" wouldn't even need metal to support it.
johnk is offline   Reply With Quote
Old 11-11-2010, 06:34 AM   #3
Thank you, JohnK.
Sophie
Old 11-11-2010, 07:03 AM   #4
Rewards Points: 150
Any reason why you cannot put a furring strip there to fill in the space and let the drip edge cover it?
guest is offline   Reply With Quote
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 09:04 AM
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
gutter apron extension steb Roofing/Siding 3 08-28-2010 05:29 AM
Installation of gutter apron over existing apron dbosh Roofing/Siding 4 11-13-2009 09:44 AM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
