Wood Stove And Metal Roof Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-19-2010, 04:39 PM   #1
Wood stove and metal roof problem
We installed a wood burning stove with proper installation kit through out and we have a metal roof. It required a rubber boot kit. On the side where the boot and the stove pipe come through the roof, there is a gap 1 1/2 inches long and about 1/2 inch wide. What can we use to fill the crack?
mesquitemagnoli is offline   Reply With Quote
Old 12-19-2010, 04:44 PM   #2
Doing This Way Too Long
Rewards Points: 532
Get the right size boot, it's obviously too big. It should be clamped anyways so you could try seeing if the clamp will close the whole thing but I doubt it.
BTW, I sure hope that's triple-wall pipe you used a boot on otherwise it's going to be a much bigger gap once it heats up.
OldNBroken is offline   Reply With Quote
Old 12-19-2010, 04:52 PM   #3
All of the issues were done as recommended and it is a triple wall pipe. Do you know of anything to fill the gap?
Old 12-19-2010, 05:07 PM   #4
DIY staff
Rewards Points: 7,174
Post a picture---There are several roofers here----
Old 12-20-2010, 12:29 AM   #5
Rewards Points: 532
Now I'm confused. Are you saying the top of the boot is not sealing around the pipe properly or there is a gap at the roofdeck? If it's a gap at the roofdeck then it's not installed properly. If it's a gap around the pipe then you have the wrong size boot.
Old 12-20-2010, 08:23 AM   #6
Roofing & Renovation
SoarRoofing's Avatar
I am not sure exactly what the OP is saying if they could post a picture it would help us all out.
SoarRoofing is offline   Reply With Quote
Old 12-20-2010, 08:56 AM   #7
wood stove and metal roof problem
I realize we need a picture for additional help. I am working on getting that. I will look forward to your advice.
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Stove pipe through roof overhang IDIY Roofing/Siding 2 08-12-2010 12:55 PM
Intallation of wood stove in Garage radl2 HVAC 3 10-12-2009 09:21 PM
Need Solution to Leaks on Metal Roof Flavio Roofing/Siding 13 11-28-2008 03:45 PM
