Wood Soffits > Vinyl - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-04-2010, 02:28 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
wood soffits > vinyl
Changing the soffits outs. a new fascia board was adding few years ago its 2x6 while the fascia was originally 2x4. So when the new soffits are 2" lower than the wood ones, do i just screw the j channel on top of the stucco and try and keep it somewhat straight or do i chip away the stucco 2" down?
ryanh is offline   Reply With Quote
Old 07-05-2010, 01:25 AM   #2
Registered User
Rewards Points: 5,244
I'd add some better soffit venting first. Check your attic square footage to figure the minimum suggested venting: http://www.airvent.com/homeowner/pro...it-specs.shtml
If those 4 holes are 4" round, about 48sq.in. total---- ideally you should have continuous venting near the fascia board: page #616---- http://books.google.com/books?id=Z8a...lation&f=false
With continuous, you get your 9sq.in.per ft. at each side of house soffit to match the 18sq.in. at the ridge (exhaust) based on 150. With a vapor barrier under the attic insulation, reduce that number by 50%. http://files.buildsite.com/dbderived...rived20936.pdf http://www.lowes.com/lowes/lkn?actio...1WH&lpage=none
Seal the attic air leaks to prevent ice dams: http://www.rd.com/how-to-seal-attic-...icle18158.html
Whoops, getting ahead of myself. Sure you can lower the soffit or leave it higher and wrap the fascia...... Stucco is very hard to grind smooth for the new soffit and look professional.
Be safe, Gary
Old 07-05-2010, 02:30 AM   #3
ryanh's Avatar
Rewards Points: 154
Hmm. I was planning on ripping down all that old wood, adding the insulation stops in the attic. Few attic vents already. How many vents per sq of roof is required anyways?.
I will probally screw a 1x2 or something on top of the stucco to attach my j channel too. Should be easier to keep straight maybe.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
seal seams on self sick tiles NoExperience Flooring 3 08-12-2008 08:25 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
