Wood Chimney Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-06-2013, 03:50 PM   #1
I have a wood chimney enclosure through a 12 on 12 asphalt shingle roof. It has an exterior backer board/stucco finish. It has a cricket with step flashing and counter flashing, but leaks at a lower corner closest to a dormer which is about 18" away. The step flashing extends up the chimney (on the wood) about two inches and about an inch down from the backerboard. The counter flashing covering the step flashing and extends up to the bottom of the backerboard. The step flashing is caulked at the top.
Can some one tell me if this a proper flash job?
Billdonne is offline   Reply With Quote
Old 03-06-2013, 04:33 PM   #2
Rewards Points: 612
Usually when I see crickets leak its because the bottom step doesn't extend past the corner enough, or at all. The bottom step flashing needs to pass the bottom corner of the cricket min 1/2", preferably more. A good roofer can make this look clean.
If it has metal valleys, the bottom of the valley needs to be bent up the wall, and pass the corner on the bottom as the step flashing would.
PatChap is offline   Reply With Quote
Old 03-06-2013, 06:13 PM   #3
Rewards Points: 12,868
Need a picture so we can see what your seeing.
Also please go back and add your location to your profile, just go to the quick links area to edit.
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 09:47 PM
Chimney Crocket on Mission Roof - Flashing Simpleaim Roofing/Siding 0 10-28-2012 08:45 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Wood stove chimney partially obstructing 1st floor window-code? Badfish740 HVAC 3 09-02-2009 09:13 AM
