Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-18-2013, 10:50 PM   #1
wind storm knocks off shingle on steep peak
A strong wind storm has torn off half a shingle (top layer as roof has been shingled twice over the years) on my roof high on on peak. There is still the old layer of roofing underneath. Is this going to leak right off?
On the other side of the house two years ago a similar thing happen with the old
layer still underneath and no leak for two years. However the newest tear is very high up and hard telling if will leak as can't get a good look at it . I am planning to replace with a new roof this summer with a contractor. Not sure what to do.....i could wait and take a chance or get it repaired to get by. A bit steep to get up there myself...though would be easy to
fix as I got extra shingles. I have a roof ladder hook thing.....but never tested it out that high up. Other option is to seal the tear with roofing cement with a pole extension and brush ( I think it would reach it ). So, access is the real issue as quite steep ( 2 stories).
I figure a repair by a pro would be in $100 range since one shingle?
sandyscamper is offline   Reply With Quote
Old 02-19-2013, 06:11 AM   #2
Super Moderator
Most roofers have a minimum charge ----So make a few calls----In my area it would be higher than $100
If you aren't good with ladders and climbing---let someone else do it-----
If you could post a picture--someone could give a good guess about a leak---My guess? No leak---
You could look up into the attic and see if the roof deck shows water marks---
Old 02-19-2013, 10:12 AM   #3
Roofmaster
Ok its a ridge cap. Where on the ridge is it? Is your ridge ventilated? In other words, are your ridge caps higher than the surrounding roof? Can you take a telephoto shot of the ridge and post it? If you go in the attic, can you see the sky through where the cap blew off?
" A lot of men build things, and a lot of things fall down "
Old 02-19-2013, 11:39 AM   #4
It is not the ridge cap, the torn shingle is about 3 shingles below the peak. Some
tar paper is ripped but appears following from the top to bottom an old first layer
is intact on the roof. Some flashing was exposed at the peak, looks like good shingles are under the flashing. It does appear a solid 1st layer exists as I used binoculars for a closeup. Will try to take a picture and post on here. My issue is I am planning to replace all the roof this summer, so wait on this tear or fix now?
Old 02-19-2013, 07:50 PM   #5
Super Moderator
If you can verify that it's not leaking----I'd leave it alone----
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
Front Storm Door Won't Latch sciron General Discussion 6 02-21-2011 10:47 AM
Wind storm today blew 2 shingles off of the house? imola ghost Roofing 1 04-15-2009 07:32 AM
shingle vent II and hip roofs tie in dondiy Roofing 2 08-11-2008 01:40 AM
