Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-28-2012, 04:50 PM   #1
will this minor damage cause leaking?
I cleared some gutters on a lady's roof. Had to clamber from tier to tier, and may have damaged some shingles. Anyway there is some minor damage, wherever it came from, which I photographed. I am hoping someone knowledgeable has an opinion as to whether it will cause leaking. You can see my finger or thumb there as a size reference. Many, many thanks.
Eric8 is offline   Reply With Quote
Old 10-28-2012, 04:55 PM   #2
Your not joking?
It's just going to rot out the fashia, soffit and some of the roof sheathing.
Shingle needs to be replaced.
Old 10-28-2012, 04:58 PM   #3
Thank you. It's going to rain right tonight. Is there something that ought to be done immediately?
Old 10-29-2012, 12:23 AM   #4
Exterior Construction
Windows on Wash's Avatar
Seal it up in the mean time and tell her to have those shingles replaced.
Old 10-29-2012, 10:32 AM   #5
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Yes that will cause damage. Replace the missing shingle. One night won't hurt.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 10-29-2012, 12:14 PM   #6
RFN-4A-LVN
Roofmaster417's Avatar
Replace the shingle.And tell the homeowner to replace that roof slope.If the rest of the slope looks like that area in the pic its a matter of time before tabs will start blowing off and widespread deterioration will occur.
From the look of the area your standing on the customer is doing section by section.Time to do another section.
Roofmaster417 is offline   Reply With Quote
Old 10-29-2012, 12:42 PM   #7
There also missing a drip cap.
Old 10-29-2012, 02:25 PM   #8
Grumpy's Avatar
That's a gable correct? Joe, I almost never see drip edge on gables here in Chicago. It's simply not done. Infact I think we do a great job, but the only time we install drip edge on the gable is when there is one existing, less than a job a year, or if we are doing a wood over wood job such as when there is spaced decking, to hide the plywood edge. Normally we will simply install a starter at the edge of the roof, that the NRCA would call a bleeder course. Also in doing the bleeder course, we get a free upgraded wind warranty from CertainTeed. I never see wind driven rain issues at rakes and gables, I guess that's why it's not done in our area.
However the overhang is incorrect, and the shingle should not be flush with the fascia.
-Grumpy
The Following User Says Thank You to Grumpy For This Useful Post:
ParagonEx (10-29-2012)
Old 10-29-2012, 08:06 PM   #9
RFN-4A-LVN
I have been working in the St. Louis area since August and have yet to do one with drip edge.It is an upgrade option here in which nobody finds useful.(Homeowners)
I am still doing work in Springfield and Joplin and everything I do there has drip 360*.And It has been that way for about 6 years.
I also use starter courses 360*.With drip edge I put 1/2" over the rake and 1" in the gutters and without I go 1" on the rake and 1-1/2" in the gutters.
I like using drip edge since I feel it gives perimeter strength.And I feel it looks better against the fascia on the rakes.
Back to the post though it seems like one of the shingles that has damage extends past the rake while the shingle above it is flush.
Old 10-30-2012, 08:51 AM   #10
Just to update, I mentioned on the other thread that I did go back and give the stuff a temporary fix with some silicone goop. Since we were set to get 1.5 inches of rain and all. Which we did.
Most of this roof has the shingles hanging out about 3/4 inch, unsupported. On the sides anyway. But much of the overhang has been crushed/bent down almost 90 degrees, in a seemingly-unintended way. A little of that was probably done by me, but most of it couldn't have been done by me. (Because I only clambered from tier to tier in two particular spots.)
Not certain, but I think the only reason you see the shingles mostly flush in my pix, is because the overhang has gotten bent down in this way -- and has, in this particular spot, eventually come clean off.
Old 10-30-2012, 11:52 AM   #11
Grumpy's Avatar
3/4" unsupported is fine in my area. If we were to install drip edge, we would install 3/4" unsupported past the drip. I know in some areas (FL) they want the shingles flush with the drip and sealed with mastic to the drip. But 3/4" unsupported would be minimum manufacturer specification.
Anything over 1" unsupported will tend to bend down over the edge from gravity and heat after a few years.
-Grumpy
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
