Will Copper Gutters Kill My Lawn/landscaping? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-26-2010, 08:02 PM   #1
mtk
Rewards Points: 16
Will copper gutters kill my lawn/landscaping?
I was thinking about installing copper gutters on my house. My father said he remembered that a neighbor had copper gutters and his lawn was always dead where the downspout drained into his yard.
I also read this http://www.cityofseattle.net/util/gr...cos_004351.pdf which says rain collected from copper roofs/gutters should not be used to water plants.
Is this an issue?
Taylor
mtk is offline   Reply With Quote
Old 10-29-2010, 09:33 AM   #2
RoofDiagnostics's Avatar
never heard this. Our office has a copper steep slope roof without any ill effects in respect to our plants and flowers.
RoofDiagnostics is offline   Reply With Quote
Old 10-29-2010, 09:06 PM   #3
No copper gutter will not affect youre yard. Most of youre water pipes are copper right? when installing make sure you use copper or stainless steel fasteners, as galvinized will cause electrolisis and corrode rapidly
jandcwright is offline   Reply With Quote
Old 10-30-2010, 10:23 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I've been installing copper roofs and gutters for 25+ years. I only know of one instance where there has been noticeable adverse affect on the plant life from runoff. It's a full copper roof with copper gutters that connect to an underground drain. Where the drain daylights, the water tends to pond after a good rain. There's about a 3' diameter area around that drain where the grass looks unhealthy.
I've read several reports such as the one you noted, but the above mentioned instance is the only proof I've seen.
If it's just copper gutters, I'd not be very concerned about it. Might be worth looking into if you have a full copper roof - I'm not talking about a bay window roof.
seeyou is offline   Reply With Quote
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 10:23 AM
how to do a copper patina on new gutters serenity7art Painting 2 09-09-2009 06:38 PM
copper gutters - can i keep them shiny? wombosi Building & Construction 13 06-21-2009 10:11 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 01:42 PM
