Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-02-2007, 04:03 PM   #1
Why is my fascia getting wet?
I had a detached garage built a summer ago. I noticed that the fascia board was getting wet in many areas and it looks to me like it is coming from the top of the board. It is a split cedar shake roof and cedar fascia. They installed a heavy black sheet paper (tar?) under the cedar. No gutters. Is there something that is missing that needs to be installed or is this an installation issue? They cut the black tar paper even with the edge of the cedar fascia and I suspected that was the problem, but they say it isn't. Any ideas?
wease is offline   Reply With Quote
Old 01-04-2007, 03:17 PM   #2
A properly installed gutter will solve your problem or at the very least, a metal drip edge installed under the shakes and extending down 3" should eliminate that. The felt should be installed on top of the drip edge
ncgrogan is offline   Reply With Quote
Old 01-18-2007, 03:37 PM   #3
Chief Fungus Fighter
Agreed. I'd install a gutter system. A drip edge will work, but it it is better to keep the water away from the side of the structure.
The alternative is that you'll be calling me or one of my associates (see my user name).
MoldBuster is offline   Reply With Quote
Old 01-31-2007, 11:56 AM   #4
Commercial Roofing
AaronB's Avatar
So they didnt hang the roof past the cedar? Is there a proper starter course?
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
How to paint trim, fascia? martyshel Painting 7 08-10-2007 10:48 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
nail removal on fascia big blue Building & Construction 4 10-07-2006 10:42 AM
fascia and drip edge glassman General Discussion 3 10-02-2006 07:39 PM
Where do I nail Aluminum Fascia? irlizard Roofing 5 08-05-2006 03:49 AM
