Why Is My 4 Year Old Roof Doing This? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-06-2014, 09:53 AM   #1
Brand new 4 year old house. I noticed the diagonal runs of shingles lifting about a week or so ago. It's been very cold (~30*F) and windy (20-40 mph). It's the left side of the first far left tab of every shingle. They've come un sealed and lifted.
Any help/advise is greatly appreciated.
jimmy77611 is offline   Reply With Quote
Old 02-06-2014, 10:06 AM   #2
Rewards Points: 14,000
Does not look like wind damage to me.
If it was wind it would have lifted the taps not just on the end of every shingle.
Looks more like a moisture problem in the attic causing moisture on the back side of the shingles.
Are there any soffit vents?
Looked in the attic for any mold or staining on the sheathing?
Dryer, bathroom, kitchen all vent to the outside?
Adding your location to your profile and the brand of shingles would be a big help.
http://prugarinc.com/shingles/proced...e-to-shingles/
Old 02-06-2014, 10:16 AM   #3
Thanks for the reply.
I'm in North Texas. There are soffit vents along with the vents at the top of the roof. I have radiant barrier decking, so with the foil side to the inside of the attic, I can't see any sign of moisture up there, but I'll give further inspection.
Everything vents to the outside through the roof. I'll inspect all the vent tubing to make sure it's intact.
This is on the back side of my house, where there aren't any bathrooms/kitchen etc. The sections of roof where all those things are, and vent, look fine. This section of my roof also doesn't get sunlight.
Old 02-06-2014, 10:35 AM   #4
I just got in the attic to check everything. No sign of moisture at all and all the vents look good. The decking looks as good as the day we bought the house, no mold or mildew anywhere. We have some boxes up there too, and they don't look like they've had any moisture damage to them.
Old 02-06-2014, 03:23 PM   #5
Rewards Points: 3,861
Looks a lot like a 3 nail shingle job to me. The installer did not lift the tab and add the 4th nail.
Colbyt is online now   Reply With Quote
The Following 2 Users Say Thank You to Colbyt For This Useful Post:
gregzoll (02-06-2014), roofermann (02-06-2014)
Old 02-06-2014, 05:03 PM   #6
roofermann's Avatar
Rewards Points: 401
Bingo!
roofermann is offline   Reply With Quote
The Following User Says Thank You to roofermann For This Useful Post:
ben's plumbing (02-06-2014)
Old 02-06-2014, 06:10 PM   #7
Rewards Points: 6,652
Your shingles do not have the tar at the front on the bottom of the tabs. The tar is actually at the top above the tab on the face.
If you want shingles that do not lift, you need the Elk Shingles, that now GAF manufactures. "Elk claimed its lamination made its product, at 1/2-inch, twice as thick as others on the market. The base was UltraMat® reinforced fiberglass, whih aided in preventing damage from fire, rot and warping. The WindGuard® sealant helped protect Elk shingles from wind blow-off."
Three Tab shingles are the worse thing to put on buildings. They are cheap, and you get what you are seeing, when they start to fail. All you can do come Spring, is go up there and use some Black Jack, to glue the tabs down, so that they last longer. Once they start lifting, then you get failure and water intrusion.
Old 02-06-2014, 06:33 PM   #8
Rewards Points: 652
Looks like the shingles were stepped at 4inch offset, not racked. I Doubt they were 3 nailed, I bet they were high nailed or overdriven if anything.
PatChap is offline   Reply With Quote
The Following User Says Thank You to PatChap For This Useful Post:
Old 02-06-2014, 07:39 PM   #9
Rewards Points: 81
I'm putting my money on a manufacturer defect.
one cut is offline   Reply With Quote
Old 02-06-2014, 08:51 PM   #10
Not likely. The defect was the person(s), that put that roof on that home.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
concretemasonry (02-07-2014), Windows on Wash (02-07-2014)
Old 02-07-2014, 06:58 AM   #11
ParagonEx's Avatar
Rewards Points: 150
Why would the installer need to lift the tab to add the 4th nail?
Look at the picture. He clearly "stair-stepped" the shingles.
ParagonEx is offline   Reply With Quote
The Following 2 Users Say Thank You to ParagonEx For This Useful Post:
gregzoll (02-07-2014), joecaption (02-07-2014)
Old 02-07-2014, 11:32 AM   #12
Rewards Points: 81
I'm trying to imagine what a roofer could have done that would cause just that corner to lift. I'm stumped.
Old 02-07-2014, 11:39 AM   #13
Rewards Points: 1,676
I'm betting on manufacturing processes and I'd even put more money down that they will look just fine about July 4.
Old 02-07-2014, 01:29 PM   #14
Most of the guys who do this for a living do not nail a full row across and then do the next row. They work 3-5 shingles wide up the roof and then start again at the bottom. As the seams have to be staggered, when they start the second upward run they have to lift the nailed shingle after they slide the shingle under to nail it. Check out the 10th picture down on this page: townsendroofing.com/our-step-by-step-re-roof-process.php
Colbyt
Retired drapery and home furnishings installer.
Old 02-07-2014, 03:46 PM   #15
ParagonEx's Avatar
Rewards Points: 150
What are you taking about? If you've been installing shingles that are stepped that way, you're doing it wrong.
The Following User Says Thank You to ParagonEx For This Useful Post:
PatChap (02-07-2014)
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 05:23 PM
Four year old metal roof starting to leak jessicahebert Roofing/Siding 2 04-05-2012 11:24 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
My 5 year old composition roof started leaking boogiebuild Roofing/Siding 6 01-15-2011 07:40 PM
Flat roof resurface--EPDM, Torch Down, Cold Applied bitumen mgfuns Off Topic 3 07-07-2010 12:10 PM
