Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-14-2011, 07:49 AM   #31
Pro Slate Roofer
tinner666's Avatar
Why Leaking Roof under Dormer / hole in OSB!!!
I like an inch and a quarter to 1-1/2". It's very old school and how water was kept from wicking in before the advent of miracle felt. Cut the tabs off 3-tab shingles and install them rightside up so the sealer strip is right at the edge and 6-nail them as low as possible.
Look closely at the pic and see how far back the water wicked. Also notice the ice stays off the fascia too. It keeps water in the gutters instead of behind them too.
Why Leaking Roof under Dormer / hole in OSB!!!-long-overhang-3-.jpg
Frank
tinner666 is offline   Reply With Quote
Old 12-15-2011, 03:10 PM   #32
I will add my personal opinion and tons of years of experience, When you get ready to put a new roof on, unless those dormers are serving you a usefull service, looks like they may be for decoration only, I would loose them, let the roofers throw a few rafters in, sheet over with osb and shingle without those babies, it will save you a ton of headaches and if the city says anything about it, tell them the wind blew them off.
guest is offline   Reply With Quote
Old 12-15-2011, 05:20 PM   #33
MB1
LOL....
Unfortunately, I love those dormers. They give the room a vaulted look and add a lot of light during the day. I've talked to a few others in the neighborhood with the same configuration, and they are not having this issue. Probably just dumb luck as I can see they have similar shingling and flashing details.
MB1 is offline   Reply With Quote
Tags
leak in roof, leaking dormer
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Help!!!! New roof leaking!!! psychomti Roofing 49 10-29-2010 01:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Supposedly 'new' roof is leaking beejay Roofing 3 03-06-2007 11:55 AM
Help- leaking flat roof, alum?metal? xoroniox Roofing 1 04-24-2006 12:03 PM
