Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-21-2008, 08:46 PM   #1
Who should replace my turbine vents?
I've got a couple of turbine vents that I need to replace pretty quickly. Is this something I should get a roofer to do? Or just a general handyman? I don't think I have time in the next couple weeks to figure it out and do it myself.
sparky472 is offline   Reply With Quote
Old 01-22-2008, 01:37 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
you should use a roofer for that so they get flashed in properly
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-22-2008, 07:09 PM   #3
Remodeler
MinConst's Avatar
A good handyman will do it fine job. If you know one that is good. If you don't your best bet would be a roofer.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 01-22-2008, 07:42 PM   #4
Super Moderator
A handy man will wind up typically setting the flashing portion ON TOP of the shingles on all 4 sides and then sealing it with plastic roofing cement.
This will keep it water-tight for only about one season, until expansion and contraction crack through the dried out roof cement and then rain will leak in.
Make sure the roofer that repairs it, describes how to get the flashings under the shingles properly.
Their is a good article on adding a vent and how to loosen the nails from the shingles on www.askthebuilder.com
Here is a specific article which shows a properly installed turbine vent. http://www.askthebuilder.com/442_Roo...ne_Vents.shtml
Note how the sides of the flashings and the top portion of the flashings are covered by the asphalt shingles.
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-22-2008, 08:50 PM   #5
very good,Ed
Old 01-23-2008, 09:50 PM   #6
Pro Slate Roofer
tinner666's Avatar
Here's more. http://www.albertsroofing.com/Power%...stallation.htm
tinner666 is offline   Reply With Quote
Old 01-29-2008, 08:18 PM   #7
Thanks everyone. Roofer it is.
Old 02-08-2008, 04:46 PM   #8
be sure to get the latest interior parts to it,for a foolproof install:
sofit vents + gable end vents no ridge vent mattg1970 Roofing 5 10-18-2007 10:47 AM
Turbine Vents- a good idea? amazer Roofing 5 09-24-2007 09:24 AM
blow power of vents mcvane HVAC 5 08-11-2007 04:28 PM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
closing vents in unused living space scottydel HVAC 1 12-05-2006 02:39 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
