-   -   Who should replace my turbine vents? (http://www.diychatroom.com/f9/who-should-replace-my-turbine-vents-15944/)
sparky472 01-21-2008 08:46 PM
I've got a couple of turbine vents that I need to replace pretty quickly. Is this something I should get a roofer to do? Or just a general handyman? I don't think I have time in the next couple weeks to figure it out and do it myself.
the roofing god 01-22-2008 01:37 PM
you should use a roofer for that so they get flashed in properly
MinConst 01-22-2008 07:09 PM
A good handyman will do it fine job. If you know one that is good. If you don't your best bet would be a roofer.
Ed the Roofer 01-22-2008 07:42 PM
A handy man will wind up typically setting the flashing portion ON TOP of the shingles on all 4 sides and then sealing it with plastic roofing cement.
This will keep it water-tight for only about one season, until expansion and contraction crack through the dried out roof cement and then rain will leak in.
Make sure the roofer that repairs it, describes how to get the flashings under the shingles properly.
Their is a good article on adding a vent and how to loosen the nails from the shingles on www.askthebuilder.com
Here is a specific article which shows a properly installed turbine vent. http://www.askthebuilder.com/442_Roo...ne_Vents.shtml
Note how the sides of the flashings and the top portion of the flashings are covered by the asphalt shingles.
Ed
the roofing god 01-22-2008 08:50 PM
very good,Ed
tinner666 01-23-2008 09:50 PM
Here's more. http://www.albertsroofing.com/Power%...stallation.htm
sparky472 01-29-2008 08:18 PM
Thanks everyone. Roofer it is.
the roofing god 02-08-2008 04:46 PM
be http://www.nrgmembers.com/forums/upl...1202486152.jpgsure to get the latest interior parts to it,for a foolproof install:
