White Around Vented Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2012, 01:06 PM   #1
Rewards Points: 28
white around vented soffits
I found that my vented soffits have a white film growing around them. Not everywhere, just near one corner of the house. Does anyone know what might be causing that?
white around vented soffits-img_1650-reduced.jpg   white around vented soffits-img_1651-reduced.jpg   white around vented soffits-img_1652-reduced.jpg
lovetobuild is offline   Reply With Quote
Old 05-14-2012, 01:43 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
Do you have blown insulation ?
Roofmaster417 is offline   Reply With Quote
Old 05-14-2012, 02:28 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Do you have attic access?
Is there a bathroom near that corner? Exhaust fan?
Old 05-14-2012, 03:58 PM   #4
Just a DIY guy
Originally Posted by Windows on Wash View Post
+1
or a dryer vent?
That's a potential disaster, but it happens:
http://life.nationalpost.com/2011/09...0%99s-not-all/
The dryer caused an even larger issue. The flexible exhaust line travelled through the ceiling of the garage and had become disconnected, blowing a massive amount of lint and moisture into that area over time, coating everything in cobweb-like lint, water and of course, mould. Not good. Even worse, the lint had also built up around a couple of pot lights and could easily have started a fire — not exactly what this, or any family wants to hear.
M3 Pete is offline   Reply With Quote
Old 05-14-2012, 07:36 PM   #5
KemoSabe
loneframer's Avatar
Looks like aluminum that is pitting/corroding due to bare metal showing at the edges of the perforations.
Moisture will accelerate this. I'd look for a bathroom fan that is terminated in the attic. It was common practice by some to run the flex out into the soffit and let it be.
I'd start there.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (05-15-2012)
Old 05-15-2012, 12:55 PM   #6
Rewards Points: 28
Thank you all so much for your help. Yes, there is a bathroom vent nearby. I do have access to the attic and there is blown in insulation. I was unable to find the end of the vent on my first entry to the attic. I guess I will have to "suit up" and head back in there again. I am assuming that this means the vent is not well connected to the outlet vent (not shown in the photos) ...and if I connect that better, it should take care of the problem.
I really appreciate your help.
Thank you
Old 05-15-2012, 02:20 PM   #7
Rewards Points: 826
Score one for this guy....
Old 05-15-2012, 02:20 PM   #8
Rewards Points: 826
BTW...vent the vent through the roof. They never work when they are dumped at the soffit or worst yet...in the attic.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Gary in WA (05-15-2012), Tom Struble (05-15-2012)
Old 05-15-2012, 04:35 PM   #9
Registered User
Rewards Points: 4,894
While you are in the attic, check to see daylight through the punched-hole soffit venting. From the pictures it appears they are not open under the punched-hole soffit. Many times this material was installed directly on the existing wood soffit which had minimal/non-existing venting. From the exterior it may look fine....
If the fan termination is not the moisture source around the punched holes, it may be also be that the insulation is restricting the intake air flow-- depositing the water vapor from the air on the insulation (dripping onto the holes) as it replaces the attic air exhausted above. This may require soffit removal and sub-soffit cutting/enlarging to get the proper NFVA required for your square footage:http://www.airvent.com/homeowner/pro...it-specs.shtml The dark colored holes may have venting under them while the white ones don't-- blocked enough by wood soffit (existing previously) yet loose enough to admit some air/moisture in a right-angle pathway. Either case--- clean the venting for optimum performance after stopping the moisture.
Gary
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
basic white paint mcl6302 Painting 6 10-11-2010 05:58 PM
turning white to antique white rustyedge Painting 6 10-01-2010 01:08 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
