Where Flat Roof Meets Shingled Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2005, 10:00 AM   #1
Where flat roof meets shingled roof
Both my house and garage roof consist of asphalt shingles on the front side and the back is EDPM over a flat roof. The shingles need to be replaced, but the flat roof is in good shape. On the garage the ridge is covered by a sheet metal cap - one side looke like it is under the EDPM the other cemented onto the first few couple inches of shingle. On the house roof there is also a sheet metal cap, but where it overlaps the shingles it is nailed and the nailheads have been caulked. What is the best way to handle this ridge cap when replacing just the shingled part of the roof? The old sheet metal ridge on the house is brown and will not blend very well with the new shingle color. Also, the house is situated so the roof is very visible from the road. Is there an attractive ridge cap that can be used between a shingled and flat roof? What is the best way to install it? Any help or insight would be appreciated! We have had a few estimates and the opinions seem to be all over the place. One roofer suggested sliding the shingles up under the cap on the house (After removing the nails - then just renailing the cap) - of course that does not address how it looks. Thanks
bstyer is offline   Reply With Quote
Old 07-07-2005, 08:34 PM   #2
Commercial Roofing
AaronB's Avatar
Can you post some pics?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
