Where To Find 2" Square Plastic Drain Pipes - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2005, 09:50 AM   #1
Where to find 2" square plastic drain pipes
I moved into my house 2 years ago. It was built in 1986. It has brown, plastic gutters with 2" square, plastic drains. I need to make some changes to re-route the drain pipes, but I have not been able to find any matching pieces anywhere. I have tried the basic places like Home Depot, Lowes, etc. without luck and tried searching the Net. Does anyone know where I can get things like this? I mostly need angled joints for the drains. Thanks.
The_Flash is offline   Reply With Quote
Old 07-07-2005, 08:33 PM   #2
Commercial Roofing
AaronB's Avatar
You could make some out of metal?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 07-08-2005, 04:25 AM   #3
Roofing Alpha male
Send a message via AIM to 927roof Send a message via Yahoo to 927roof
making a custom one sounds good, myself If you have the gutters I'm thinking of I wouldn't spend a great amount of money on it. Ever ask why it's hard to locate parts? The ones I've seen (plastic section gutters) are typically shot by the age yours are now, and without seeing yours I maybe very wrong?? If you want you may want to try the big stores like lowes or Home Depot farther away or in other states cause I'm sure I saw that stuff somewhere not long ago?? Hey try to locate where it use to be sold and see where they use to get it, or maybe it still has a name on it somewhere and talk to the manufacturer?
927roof is offline   Reply With Quote
Old 07-08-2005, 10:50 AM   #4
GMW
I would try and look on some of the other parts for a manufacturer. I am willing to bet that you will find either Genova or RainGo on it somewhere. I am not sure if they are still in business. I think SnapNSeal bouht them out. I know they were big in the 80's. Good luck.
GMW is offline   Reply With Quote
Old 07-25-2005, 07:35 AM   #5
Grumpy's Avatar
Rewards Points: 524
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
gah! plastic gutters. Awful!
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Collapsed Drain Pipes Piney Plumbing 1 11-09-2006 04:46 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
