Where Do You Buy Z Flashing? In Small-town Quebec? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-02-2013, 09:15 AM   #1
Rewards Points: 12
Where do you buy Z flashing? In small-town Quebec?
So I went on a hunt to buy z-flashing yesterday, and at all three big box reno stores here (Home Depot, Rona, and Reno Depot), all I got were blank stares and shrugs. Some will bend aluminium for $3.80 a foot.
Lots of fascia and drip edges, no z-flashing. Any idea of where else I should look for this stuff? I'm burdened with the extra challenge of trying to explain this in French.
PantsMasterson is offline   Reply With Quote
Old 09-02-2013, 09:39 AM   #2
PoleCat's Avatar
Rewards Points: 1,638
It is commonly used with the T 111 siding so if they sell that particular siding they should have or be able to get the flashing. You may have to draw a picture and use only single sylable words to communicate with the oracles at the big box stores.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-02-2013, 10:00 AM   #3
kwikfishron's Avatar
Rewards Points: 86
Go to one of the bigger HVAC companies, they'll have a large brake and will bend up whatever you want. $3.80 a foot seems out of line to me, I can get stainless steel Z bent for about $1.60.
Strange that the box stores don't stock it. I looked on a Quebec HD site and couldn't find it either.
kwikfishron is offline   Reply With Quote
Old 09-02-2013, 11:52 AM   #4
Civil Engineer
Rewards Points: 4,514
You can make your own Z flashing pretty easily by building your own brake. I made a crude brake using a hardwood 2x4 screwed down to a piece of plywood. I got the idea from a This Old House episode. I made my own copper Z flashing for several windows and a door, and I bent some aluminum flashing for a deck. Worked quite well, all I had to do was buy roll copper and roll aluminum, much less expensive than purchasing premade Z flashing, plus I could make the flashing whatever width was necessary.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Windows on Wash (09-03-2013)
Tags
finding , flashing , stores , zflashing
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 08:36 AM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 06:51 PM
Skylight flashing Swamp Yankee Roofing/Siding 1 08-13-2010 11:48 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 01:50 PM
Bad job replacing chimney flashing? TNVolFamily Roofing/Siding 12 02-28-2010 08:04 PM
