Old 06-27-2014, 11:59 PM   #1
Share |
When/where is ice and water shield generally installed?
Besides meeting local code, what are the application scenarios for it?
Eaves?
Valleys?
Low pitched roofs?
Around vent/pipe flashings?
Near walls?
daluu is offline   Reply With Quote
Old 06-28-2014, 05:00 AM   #2
roofermann's Avatar
All of those. Cover the I+W with felt or synthetic underlayment, otherwise the next guy will have to tear off the sheathing too.
roofermann is offline   Reply With Quote
The Following 2 Users Say Thank You to roofermann For This Useful Post:
oh'mike (06-28-2014), Windows on Wash (06-28-2014)
Old 06-28-2014, 06:12 AM   #3
Eaves?
Valleys?
Low pitched roofs?
Near walls?
How does your local code read?
For those that don't have codes for I/W shield it is generally installed from the eaves up and beyond the building line a short distance. That's for those people that believe it will solve their water in the walls problem when ice dams occur and that is basically true if the installer gets a 100 percent seal.
What those who write codes and others don't know is water will find its way into the attic in other areas when the eaves area is successfully blocked from water intrusion during an ice dam problem.
Can the whole roof be covered in an attempt to curtail water intrusion? Sure. Will a roofing company guarantee 100 percent their installation of I/Water shield will not all any water to enter during ice dams? I highly doubt it.
Fairview is online now   Reply With Quote
Old 06-28-2014, 10:53 AM   #4
Where to find the local code info for ones city, county, state?
Old 06-28-2014, 03:27 PM   #5
Exterior Construction
Windows on Wash's Avatar
Google the IRC or just call your local office.
Old 06-30-2014, 08:33 PM   #6
Roofmaster
Minimum 2 feet inside the exterior wall line at the eaves is the rule of thumb. I spec the drip and rakes to be enveloped with a 12 and 18 inch piece of Ice Dams Membrane. The flange of the drip is sandwitched between Ice dams.
" A lot of men build things, and a lot of things fall down "
Old 06-30-2014, 08:34 PM   #7
Roofmaster
Minimum 2 feet inside the exterior wall line at the eaves is the rule of thumb. I spec the drip and rakes to be enveloped with a 12 and 18 inch piece of Ice Dams Membrane. The flange of the drip is sandwiched between Ice dams.
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
