When Is Shingle Up Lift Normal - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2013, 07:59 AM   #1
Lord of Slums
Rewards Points: 1,974
When is shingle up lift normal
I will try and get a pic today- I have a 13 year old roof, it is the architect type asphalt shingles. I noticed that two shingles right on the edge of the roof are starting to lift up. When should i be concerned, what is something I can look for. This is the only spot I can see.
mj12 is offline   Reply With Quote
Old 05-07-2013, 10:50 AM   #2
Doing This Way Too Long
Rewards Points: 532
Not much we can tell you without seeing it. Anytime shingles are lifting up you need to be concerned to some degree. If they aren't sealed down properly a good wind can take them away. Lifting is also a sign of age on a shingle also.
Don't know much without seeing it.
OldNBroken is offline   Reply With Quote
Old 05-07-2013, 04:36 PM   #3
Lord of Slums
I went over the whole roof and I found these shingles lifting up. Minor lift but want to know what action to take , if any at all. The shingles in question are above the left arm of my stabilizer.
When is shingle up lift normal-hpim2096.jpg   When is shingle up lift normal-hpim2097.jpg
Old 05-07-2013, 05:50 PM   #4
Rewards Points: 532
Looks like the wind caught them. It lifted the little scrap one and, in turn, that one lifted the corner above it. Little dab of asphalt and some sun may lay it back down.
Old 05-07-2013, 09:10 PM   #5
Roofmaster
Rewards Points: 2,172
Dollar to a doughnut, you will find nails popping up under those shingles. Lift the tab carefully, and pop the nails out with a wonder bar. Set the tabs in a half dollar sized dab of urethane sealant over the nail holes, and weight them down overnight with a plank bucked up to the ladder. Tie off the ladder well to a gutter bracket.
Other than that your roof looks really good. Good pictures. You walked this roof????? You must be a Mountain Goat
Old 05-07-2013, 10:22 PM   #6
Lord of Slums
Not really walked it. Did some sloaping with my sponge. Went up over to the left, I screwed boards through the shingles. Not as bad as it looks really.
Old 05-07-2013, 10:26 PM   #7
Roofmaster
Cmon, you are pulling my leg. You didn't really screw through the shingles did you?
Who are you, Silicone Sam from Direct TV?
Old 05-07-2013, 10:29 PM   #8
Lord of Slums
That bad, crap. Two very small holes.
Old 05-07-2013, 10:36 PM   #9
Roofmaster
Well you should have used roof jacks. ( Slap, Slap) Now you have to bib them with ASTM D-226 Type 2 felt and roof cement.
Overflow drain stained black, normal? Drywallhelp Plumbing 5 08-14-2011 08:48 PM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 11:09 AM
We're reroofing - shingle warranties from major manufacturers more or less same? Catpat Roofing/Siding 0 03-25-2010 03:59 PM
Corner of Shingle Broke Off sweaty Roofing/Siding 1 09-09-2008 10:11 AM
shingle vent II and hip roofs tie in dondiy Roofing/Siding 2 08-11-2008 01:40 AM
