when to replace a skylight & flashing question
There are gutter apron drip edge flashings, which typically should match the color of the gutters or eave fasia boards if you have no gutters.
There is gable side edge ODE, overhabging drip edge flashings, which should eithe match the color of the fascia on the gable sides or can match the color of the shingles.
The are step flashing baby tins against wall intersections, which typically are mille finish aluminum and are mostly concealed by the siding and the shigles.
There are skylight flashigs which come with the skylight kit and come in several colors, but should be similar ro the shingle, but bronze is the most popular color sold.
There may be brick chimney flashings, which can be pre-colored to match either the color of the chimnsy brick or the shingle color or be made of lead or copper.
There is valley flashings, which can also be a pre-colored metal to match the shingles or to match the shingles.
There is pipes which penetrate through the roof and they can get painted as long as they are cleaned off of any dirt or oils, by using an exterior "Rustoleum" type paint. It does not chip or peal away any more than the paint on any other exterir painting you see done around a house.
You may have a sheet metal chimney housing which covers the hot water heater and this can be repainted in either a stone cultured look type paint or in a color sequence to re-paint the fake bricks and fake mortar joints. I have many pipes and chimney flashings which are over 10-12 years old since I started painting these penetrations on roofs and they still look remarkably well, with no sigs of excessive weathering or pealing.
So, which flashings were you inquiring about?
Now, about the skylights. See Mikes answer above. There is no need to spend alot of money right now, if they are in good shape, but if they are starting to look faded or yellowing, then they should be replaced with the roof at this time.
Ed
