Whats The Proper Method - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-03-2008, 09:28 PM   #1
whats the proper method
Im building a home and im roofing it with one of my friends(a roofer). The framers ran the drip with ice/h20 shield under the drip while my buddy says it should be drip then ice/h20. its a 12/12 roof so im not super concerned, but would like to see if there is a proper method.
Allready knocked off about 14 squares, but still have 60 left
NHERal is offline   Reply With Quote
Old 11-03-2008, 09:44 PM   #2
You don't trust your roofer? All installation instructions I've seen has the bottom drip, then the roofing felt/ice shield, then the side drip edge.
jerryh3 is offline   Reply With Quote
Old 11-03-2008, 10:25 PM   #3
not that i dont trust him, just i dont know and im getting two conflicting practices, just trying to get a few more inputs.
Thanks for the info.
Old 11-03-2008, 10:30 PM   #4
Ice and water over the drip at the eaves and under drip at the gables.
johnk is offline   Reply With Quote
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 12:57 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
Which bonding method proper??? Nestor Electrical 2 09-15-2006 06:18 AM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 01:38 PM
