What's A Chase Cover? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-24-2012, 09:56 AM   #1
RockfordChimney
Post
What's a chase cover?
Thought this information would be useful for all my fellow DIY'ers; don't forget about your chimney during these summer months... fall will be here soon! Happy DIY'ing
What Is A Chase Cover?
It is a shield that covers the top of a chimney, or chase, to prevent rain, melting snow, and everything else from entering into the chimney chase. Take a look here for stainless steel chase covers and how to measure and install your chase cover:
We all know what happens when a roof has a hole in it or is not designed properly...You get a leak. In addition, your chase cover may already be leaking, causing thousands of dollars in damage that you may not be able to see until it is too late!
The standard skirting / flashing is 3" with a drip edge. The chase covers the entire top of your chimney. Used frequently to cover chimney chase surrounds, it fits over the top of the chimney like a shoe box cover fits the top of a shoe box.Chase covers come in any size, any shape, copper or stainless steel, multiple vents, the list goes on, it's all up to you.
Think twice before using galvanized they may be less expensive but these repairs are only temporary. Galvanized covers rust over a short period of time (another reason why you may need to replace your chimney cover). Once it starts to rust, it bleeds down onto the siding or brick of the chimney and leaves an unsightly stain. Rockford flue covers will last a lifetime. We custom make every chase cover you can imagine, from 16" x 16" all the way up to 100" x 100".
Last edited by Gary in WA; 07-29-2012 at 03:05 PM. Reason: Removed advertising link as per forum rules.
Rockford is offline   Reply With Quote
Old 07-25-2012, 08:43 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
Good post
We fabricate ours out of stainless and weld the corners when replacements are required.
Cheap insurance.
Tags
chimney , chimney cap , chimney chase cover , chimney installation , chimney surround
chase top cover bellingham Building & Construction 5 02-22-2012 10:21 AM
Cover for artesian well? bw77 Plumbing 6 11-28-2011 07:06 AM
Patio Cover Design Question? Rclancyc Building & Construction 3 10-04-2011 02:07 PM
Garage Drain Cover matt151617 Plumbing 5 08-09-2011 08:56 PM
Exterior Flue Enclosure Repair edge10 General DIY Discussions 6 08-03-2009 09:15 PM
