Whats Causing Rain To Go Back Up Into The Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-27-2012, 10:13 AM   #16
Rewards Points: 13,300
My money goes on the shingles being laid with no overhang.
I see this all the time on store bought sheds, they never have an over hang so they do not blow off going down the road, the bottom edges alway rot out after a few years.
Also lift the top layer of shingles to make sure they used a starter cource of shingles. (first row gets one tab cut off and is installed upside down so the tabs on the first row do not leave bare wood exposed)
dcastillo (06-27-2012)
Old 06-27-2012, 10:25 AM   #17
Originally Posted by danpik View Post
Realy kind of hard to see in those pics but, does your drip edge have a small overhang like in this picture?...
I would also suspect capilary action drawing the water back under the overhang too. The little kickout on the dripedge looks almost flat in some sections. That could be bent out a little to "kick" the water away.
they definitely dont have an over hang like the one you attached, which I thought was odd as well
dcastillo is offline   Reply With Quote
Old 06-27-2012, 10:28 AM   #18
Originally Posted by wkearney99 View Post
How did the room flood? From the water getting in from above? Or from it puddling on the ground below?
I can see wet spots where the ceiling and wall met going down about a foot or so... then its all dry from there...
until the floor, but even the wall a few inches above the floor is dry...
Old 06-27-2012, 10:32 AM   #19
Bill Kearney
Rewards Points: 1,174
I second the question about the shingle overhang. There has to be enough angle and length to allow gravity to overcome surface tension and allow the water to fall. Perhaps new edge and some gutters is the best course of action.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Old 06-27-2012, 10:47 AM   #20
Thanx, that what Ive been gathering so far...
seems like I have a fairly simply fix, probably just get a new drip edge it...
now I just need to figure out how much water damage I have...
think Im going to try and pull up my floors tonight with minimal damage so I can reuse them....
thanx again for every ones advice
-Danny
Old 06-27-2012, 11:02 AM   #21
Bill Kearney
Get a fan in there and start blowing a lot of fresh air around the space. Moisture is the enemy here, and mold isn't far behind it. Consider that your homeowners policy may cover calling in the professionals (like ServePro) to deal with this. Yes, it'd be messy but cracking open the drywall to air it out may be the best plan. Better to have to deal with some drywall and paint work now, versus health issues from mold AND the same drywall and paint work later.
Old 06-27-2012, 11:08 AM   #22
Remove the base boards and make a cut just below where the base boards were sitting and remove all that sheetrock asap.
Start running a dehumidifier ASAP.
That about all Servpro or any other damage control companys going to do and be far cheaper.
Old 06-27-2012, 11:24 AM   #23
Rewards Points: 252
I'm going to disagree with everyone here. I can't as much water as indicated making it's way inside from the drip edge or from the wall. If you look closely you can see that there isn't much water at the wall, and there is a sheet of water coming out the lower piece of metal under the drip edge, which says to me it is getting in from under the shingles.
If you could get a picture of that upper valley, that would be great. I'm guessing A) there is an issue at the bottom of the valley or B) the valley is closed cut, but the cut was done on the lower roof instead of the upper.
Edit: another point, oveerhang is typically created by extending the top chord of the truss, meaning the drip edge would be lower than the ceiling height. The soffit was most likely built after the wall below was sheathed. Not to way water isn't getting in at the drip edge and possibly rotting out the fascia, but it wouldn't be going anywhere near the interior.
shazapple is offline   Reply With Quote
The Following 2 Users Say Thank You to shazapple For This Useful Post:
dcastillo (06-27-2012), Windows on Wash (06-27-2012)
Old 06-27-2012, 11:41 AM   #24
thanx for all the advise...
we dont have any more rain headed are way at the moment, and I should have two roof companies coming by in the next week hopefully to look it over...
now I need to figure out what to do about my laminate flooring, which I will post in the proper section
Old 06-27-2012, 07:07 PM   #25
Also check to see if the sofit is level, if it's low at the house, that can cause the water to wick back to the house, seen it happen before, always keep the facia metal a little low so that don't happen.
Kpaul is offline   Reply With Quote
The Following 2 Users Say Thank You to Kpaul For This Useful Post:
dcastillo (06-27-2012), Tom Struble (06-27-2012)
Old 06-28-2012, 10:47 AM   #26
got up on the ladder today, Soffit looked pretty level...
I attached a few more pics to see if the extra detail helps out at all
thanx
danny
Whats causing rain to go back up into the soffits-img_20120628_080108.jpg   Whats causing rain to go back up into the soffits-img_20120628_080125.jpg   Whats causing rain to go back up into the soffits-img_20120628_080133.jpg   Whats causing rain to go back up into the soffits-img_20120628_080145.jpg   Whats causing rain to go back up into the soffits-img_20120628_080155.jpg
Old 06-28-2012, 11:38 AM   #27
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Yep. DE catching the water. The shingles change angle in the last inch because the DE is sitting level.
Further investigation will probably show it's nailed on top of the fascia. Idiot carpenters nowadays think they're saving something by stopping the sheathing somewhere behind the fascia. It's supposed to run 1/2" to 3/4" over the fascia.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
dcastillo (06-28-2012)
Old 06-28-2012, 11:40 AM   #28
Pro Slate Roofer
tinner666's Avatar
And though MD roofing policies defy everything a roofer knows, that wall doesn't appear to be leaking. I don't see in any staining under the soffitt at the wall in the last pic.
Old 06-28-2012, 12:20 PM   #29
so if I follow:
-the water under the soffits should be fixed, but its not my issue
-the issue is the last 1-2" of the roof has a slight bend back upwards causing the water to puddle a little instead of running off freely?
is that correct?
thanx
Danny
Old 06-28-2012, 12:35 PM   #30
Rewards Points: 2,210
That and your shingles do not overhang your eave.
Also there may not be (probably isn't) ice and water guard at the bottom of the roof under the shingles and on top of your roof edge flashing.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Soffits and attic ventilation mikiek Roofing/Siding 3 06-03-2012 12:10 AM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
Wooden Tongue & Groove Soffits Beverlyb Roofing/Siding 2 08-30-2008 11:31 AM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 01:45 PM
